vetterss
Does anyone know what the size is for the 3 bolts that retain the chrome center caps on the steel 17" wheels of a 2009 PPV? Searched a bunch of sites but no luck. May have to take one off and try to match it at Lowe's.
I used the stainless bolts too on mine along with stainless washers. There are suppose to be some small aluminum spacers between the cap and wheel too. I was missing a few and found a 3/8 inch nut slips over the bolt threads to use as a spacer. The cap is not clamped to the wheel around the outside, but by the bolts and spacers.
What is the thickness of the 3/8-inch nut?
I found aluminum spacers at Home Depot that are the same size as the factory spacers. Dimensions are 5/16" inside diameter x 5/8" outside diameter x 7/16" length.
Also, the factory spacers have 2 O-rings that hold the spacer on the bolt from the inside of the center cap. I just used one O-ring, which is 1/4" inside diameter x 3/8" outside diameter.
See attached image for reference.
This is the closest i could find at HomeDepot
https://www.homedepot.com/p/The-Hil...ick-Heavy-Duty-Spacer-5-Pack-883492/204726380
Need help!! My center caps won’t stay on because the pilot hole inserts came out. What can I do ??
View attachment 214041 View attachment 214042
