Icarsoft i990 cant find autoride
Coach Larry
having very loud compressor issues and bought i990 to diagnose suspension and other items.
i am not getting any codes, nor can I find any section that lists autoride in the software.
Can someone point me in the right direction to make sure my scanner is working properly? I updated firmware when I purchased the unit. I enter the infor for my 2005 Yukon Denali with fifth VIN letter K, which should be a Z55 Autoride I believe.
GeorgesBlazah
South Jersey
I dont have my reader in front of me but mine is listed under chassis.
a loud compressor is simply that nothing will make it less loud, (except replacing it) if you have a leak then it will run more often, you can spray the shocks and lines with a mixture of soap and water and see if you find any leaks.
briannorris
