Pioneer AVH2330 NEX in Tahoe Hybrid
LYK2ROC
https://www.amazon.com/Pioneer-AVH-...520355093&sr=8-2&keywords=pioneer+avh-2330nex
This is the unit I am looking to purchase. I have a 2008 Tahoe Hybrid with Factory Bose cd/dvd, rear dvd screen, navigation, back up camera, steering wheel controls, etc. I want bluetooth in the worst way, but why not just spend a little more and get a whole new system?
I just spoke with a gentleman at Crutchfield, and he said that this will not transmit the dvd to the rear monitor. There has to be a way to do this, without purchasing a whole new rear unit. The unit he was recommending was a Boss unit and it was a regular roof console, that could be controlled either way with the Pioneer Unit or just a remote or the controls on the dvd unit itself. But it was another $400. Any ideas? I have a 2016 Silverado and I am spoiled with the Chevy Link, and think this would be a great addition to the Tahoe. Not to mention. Everything would pretty much be hands free. I am a realtor, and I do alot of driving, so it would be very handy. Thanks in advance!
NathanJax
Vacation Nathan
Jax, Fl
So, to answer the first part of your question, you just need the correct harness to retain RSE (Rear Seat Entertainment). The Metra AX-ADGM100 will do that.
http://www.metraonline.com/part/AX-ADGM100
HOWEVER
, the hybrid system goes through your radio. There's a bunch of threads on this in the hybrid section, but no one has yet to successfully swap the radio out.
L
LYK2ROC
HOWEVER
It does go through the radio. It just shows when it is charging and when it isn't. I didn't know that that would affect anything to just not have that anymore...
Ob1hybrid
Wonder if he did it. Seems like no one has done it before, or at least tried. An installer once told me before anything to just disconnect the radio and drive the truck and see what happens.
Eddie08
I think I might just disconnect the radio and see if all still works fine as I believe its just a lil show for you to watch on your radio . I am tired with the dated stock radio.
I would look at the maestro idatalink website, plug in your info (year make model & radio to be used) and see what options it retains, the website will give you complete details of what the idatalink and radio can do or wont do. the idatalink module is programmed via usb on your pc or laptop.
Eddie08
i agree with checking idatalink car cable and module for use with the 2330nex. I just put in the 2300nex in a ford escape. Son programmed module to use the steering wheel controls like he wanted and it also had a OBDII dongle so he could see tire pressure and some other items on the radio. Sure it differs from car to car but for once I just soldered about 12 wires and worked the first time (I rarely have luck the first time).
Rickz04Yuk
Cali (South Bay)
Have you removed the radio to see if you had any issues?
I saw a video on Youtube of a Hybrid Tahke with an after market radio behind a custom ipad dock, looked pretty damn clean and didnt seem to have issues.
I doubted at first it was a hybrid, but watched the video and the Hybrid emblems were clearly visible. I'm currently considering purchasing a new HU with Navigation or adding iSimple or BlueFusion Blutooth to it.
I've only had my truck for 7 days and I'm already tired of n9t having BT functions.
Ob1hybrid
Gotta keep this thread alive. We need to get to the bottom of this. We need pics and everything.
Ob1hybrid
I'm thinking worst case scenario, that system uses headunit for whatever reason, you swap the HU out completely but keep just the hybrid feed connected to oem HU stashed somewhere in the the truck.
if you guys just go to the website I linked above it will tell you everything you need to know. all you have to do is enter the stereo make/model and vehicle make/model and then it will give a list of options it will provide or not provide or if it is not compatible.
extremetint
I have removed my oem navigation and put in kenwood dmx7704s along with idatalink maestro and now have android auto and kept all factory accessories, Rear entertainment backup camera xm satellite
Andrew l
I have Bluetooth function on my hybrid. Stock HU. I just paired it with the factory Bluetooth commands. I use Siri to do anything I need while driving.
I seriously doubt they would put anything that would be detrimental to the operation of the vehicle in the radio if so it would essentially turn the radio into part of the bcm, just like you can unplug and remove the instrument cluster and it affects nothing other than throwing a code eventually that it cannot communicate with the cluster.
dnt1010
Tennessee
I have a stock 09 Tahoe Hybrid and it has Bluetooth on it that I use every day? Are you saying that the 2008 model DID NOT have bluetooth capability? If that is the case I wonder if a 2009 or later salvage factory Hybrid radio unit would swap in for you? Are you 100% sure that your 2008 does not have Bluetooth capability? I did not realize that mine actually had Bluetooth for a while either.
wwiizz
