Show off your exterior lighting mods
TwiztidPixel
Anderson, SC
Front:
Hikari 6000k LED low beams
"Stark" Phantom 6000k fogs
Nilight 6000k 20" light bar
eBaytastic LED bumper lights
Rear:
eBaydiculous LED tail lights
eBaylorious LED 3rd brake light
eBaylicious 6000k spotlight reverse LED bulbs
Philips 6000k license plate LEDs
Other:
Xprite 3rd Gen 8-pod rock lights
BADRIDES
Front:
Rear:
Looking good
ladorn45
I installed rear fog lights to the car. Just wanted throw this mod out for those who want to add backup lights but not drill into anything.
I used
-2in pipe clamps from home depot
https://www.homedepot.com/p/Cramik-...anized-Split-Ring-Pipe-Hanger-20007/100182521
- 3/8 bolt
- Fog lights from amazon
https://www.amazon.com/gp/product/B01EJWB62U/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
- and Rubber mastic electric tape
https://www.homedepot.com/p/3M-Scot...ic-Electrical-Tape-Black-50727-BA-5/202195402
All i did was drill out the fog light whole to fit the 3/8 bolt and attached it to the pipe clamp(also used a 3/8 nut for spacing). Added mastic tape instide the clamp for grip and then took the pipe clamp and attached it to trailer hitch of the car
IMG_20180120_084033612.jpg IMG_20180120_084038531.jpg IMG_20180120_084045766.jpg
DirtyHoe2002
SE Nebraska
Just a few of mine from over the years.
True 55w HID Morimoto Mini H1 7.0 projector retrofit, 7" LED bar fog replacements, 21" bar in valence (wired to the fogs), with "HI-7" mod:
Underhood LED strip with hidden switch:
LED mirror courtesy swap (I really like the mod from the first post, though, I think I might do the same!), VLEDs Triton V3 backups in Spyder LED housings, aux under-bumper backups (going to be replacing with brighter and relocating farther under the bumper, out of sight this week), underbody LED pods wired up with courtesy lights:
The underhood led strip is badass, I might just have to do that. I bet it's pretty handy at night.
DirtyHoe2002
SE Nebraska
camaroz1985
All of my lights are now LEDs. Did the 4 switchback mod with amber corner lights. All switchbacks light as DRL and parking/turn signals. Also used the Novita electronic flasher so no resistors are needed, and I previously did the diode modification so I have All-On-High. I like the result.
HiHoeSilver
Away!
Chicago
I like it. What color temp are the leds? Which ones did you use?
camaroz1985
The headlights (Auxbeam F-16) and fogs (Something cheap from Amazon) are 6000 K I think, and the switchbacks are Super Bright LEDs (Type A). They list them as 5000 K, but they look like a match to me.
Mckennahc
