Cargo Area Light Mod
dbbd1
Today, I added some white LED bolts/ eagle eyes/ whatever to help brighten up the cargo area. I just tapped into the fuse block at the rear driver's side. There was even a male spade unused. I did put an inline fuse into the circuit too. I used a 10 amp, only because I did bot have a 5 amp laying around right now, the 4- 9w LED's (if that's true) should draw about 3 amps total. After you look at the pic's, you'll see why I am glad that I did not use 6 of them.
The first pic is with them off...
The next is with them on...
And this one is just showing the eagle eyes (2 of the 4)...
In the second pic, between the 1st and 2nd eagle eye from the left, you can barely see a blue dot. That is the indicator on my switch for the lights. I would have loved to tie them into the dome circuit but I just didn't want to give them that much thought. The manual switch will work just fine. Where I tapped into the rear fuse panel has +12v all of the time too. I did think about using some of those COB white lights that are advertised for "DRL's" but these are more directed and no glare.
(pic's were taken with flash off, in case you're wondering)
Off1c3r
Nice job! Looks really clean. I literally was thinking about doing this project today. Can you provide any other details on the installation process? Issues you ran into?
dbbd1
dbbd1
0 issues. It went nice and smooth. I'll take a pic of the +12v point that I used tomorrow. I was very careful where I put the lights. They are 1" tall on the back side. I believe I put them all in 1-1/2" in towards the front from the back edge/lip/curve. Then I more or less placed them next to the standoffs where the panel clips would go. I say "would" because on my panel, I had, I think, 3 clips that were not there. Not missing, probably never installed. The few clips that hold it up are more than sufficient. On that note, those clips, which are red, are buggers. They hold tight. I was able to shine a light in there, while prying the panel down a bit and with my third hand, use a long screwdriver to help pop them out.
The switch is in a similar spot, close to a standoff.
Because I am slightly OCD (that's like I am slightly Polish, ha!), I put in female/male spades near the switch so that I can remove the whole panel without removing or cutting any wiring.
dbbd1
dbbd1
Here are pics of the +12v and ground points. I just added another metric to the stud and secured my ground that way.
My fuse is inline, so you don't see it in this pic.
08grey
Here are pics of the +12v and ground points. I just added another metric to the stud and secured my ground that way. View attachment 191723View attachment 191724
Quick tip. The reflector on the eagle eyes like to fall out. If you pop it out and add some clear silicone and reinstall it will stay forever. Nice clean job!!!
Sent from my SM-G950U using Tapatalk
dbbd1
dbbd1
Can you do mine? I have nice bourbon!
If you bring it here (or pay for travel), I'd love to, actually. Heck, I still have 6 lights out of my 10-pack leftover...
But, bourbon? I'll pass. I'm a gin or tequila (straight up) guy.
05Single
afraid of the dark
Yep. Happened to both my mirror/puddle lights. But they're still just as bright and actually spread out more instead of the focused beam patter from the projector lens. My cargo lights are still intact so far. Wasn't even mad since they're basically $1 each lol.
Since David did not mount on any moving part (door, hatch) they should stay together :shrug:
4 is way too much for me, but it's all about preference. Clean install and welcome to the elite cargo light club lol :winner_first_h4h:
dbbd1
dbbd1
Hope I didn't steal your thunder. Did you already do a thread on cargo area lighting? I never checked...
And, I'll have to check for your puddle light mod.
dbbd1
dbbd1
Whew, okay, dont want to step on anyone's toes. I thought it might have been in this (+15) forum.
I'm Dave and I'm a lightaholic...
Fosscore
:lol2:
He won't feel the stomp, they are frozen in Alaska at the moment. All mods are good especially the lighting ones. He put that up for anybody to contribute just like this one you did. Nice work. Put up some more, even though I know you are in the 15+ section.
05Single
afraid of the dark
No no no this is what this place is all about , sharing ideas. Could care less about credit or thunder. You had a great idea and applied it to a newer model....which suprises me that theres still no damn light back there from the factory :nono:
Off1c3r
Awesome, thanks! Also, thanks for the additional photos!
4wheeljive
I am hugely indebted to the OP, David. The lack of lighting in the cargo area has driven me nuts, and I struggled over how to deal with it. I ended up copying David's solution almost exactly, and I am thrilled with how it came out. I also took things a step further to light up the exterior space behind the truck. I'll follow up with a few pics.
Korbin_A
