winter driving
tahoe 5.7 ss
minnesota
Does any 1 cover there grill in the winter? i was thinking about covering mine ,,its -10 wind sheild -30 i do alot of highway driving. let me know if its even worth doing ..
92__silverado
I once made a 4 hour road trip in a truck with a lower t-stat and no heat. Talk about miserable. I would say if your car is having trouble getting warm it would hurt to cover a bit, if you do it just make sure to keep a close eye on your temp. You do not want to over heat. When you say -30 do you mean wind chill?
99Yuk
Northern Ontario, Canada
I just drove 7840kms over the holidays.
I was using a **** trip computer/e-gauge to monitor the water temp.
Outside temps varied from +4c to -22c.
My water temp never varied much from 84c idle to 89c WOT going up big hills.
My dash gauge needle never moved from 90c.
I had plenty of heat in the rig.
I was thinking of covering the front a bit, but this trip made up my mind to just leave it alone.
AtomicHoe094
Atomichoe094
cleveland, OH
naa, instead of the cover idea, get some electric fans. That way your motor heats up about 5 times faster then if you motor had its orignal fan. A lot of good things happen with electric fans
TheBeast99
doesn't running the stock electronic clutch fan have advantages too? i mean you'd think i'd never have to worry about the fan not coming on since it's driven directly by the engine :)
AdrienR
