Expected transmission life span
CamReynolds
My mother in laws tahoe went 230k with the original tranny before she suddenly got stranded on the side of the road with a back glass covered in atf. She towed trailers left and right with that thing.
Idk how. Our 2nd gear dropped out. It's ok, got a rebuilt heavy duty tranny with a shift kit out of it
mattt
My '04 has ~258k on the original and still driving. (Knocks on wood) It does funny shi(f)t if I'm on the gas, let off for a second or two, then get back on the gas. When I do that, it will act like it's slipping, and allow the engine to rev up. I always back off the skinny pedal, then it returns to normal. I've changed the filter twice and did a pan fluid drop via the pan drain plug a few more times than that. I think the new fluid infusion mixed with the existing does help. I feel a shift quality difference when the pan drain and refill is done. I do tow a few times a year,,,,,,a boat, a buggy, a rzr. With my trailer, it's usually a few thousand pounds of tow. Drive smart, pay attention to what your trans is telling you when driving, service it even somewhat regularly, and it should last.
fasttruck9
I have a 2012 Hoe 5.3l not sure what trans but mine went at 124,000, Chevy installed a reman at the cost of $3900.00 7,000 miles and 6 months later it's back in for a new trans, the trans came with a 3 year unlimited miles warranty but it is still a PITA.
LJPinDrakeND
Drake, ND
Our 2010 Hoe has over 140K on it and running great. Change the fluid, occasionally driven like I stole it (foot through the floor acceleration), and rarely tows anything. Not a burp or peep out of it. Damn good hooptie.
Knope
NC
Everyone has different luck...I'm currently at 238k. It has been used to tow boats trough the mountains of NC, tractors to farms, loads of lumber and tile when remodeling houses, and even a broken-down BMW for a 3 hour lift. Bone stock and never had the fluid changed...actually I may drain the fluid tomorrow haha.
rockola1971
Indiana (formerly IL)
If it feels like its slipping...its because it is. Your 2-4 band is slipping. It wont be long now.
mattt
I'm not so sure of that. I've been able to make it do that for well over 50k miles. It is 1 particular combo of on the gas, off the gas, on the gas. Not only have I been able to replicate this with my current 04 Tahoe, it also did the exact same thing in an 01 Suburban I used to drive. I suspect it's something in the valve body programming, where possibly the converter goes into free wheel when coasting from a certain speed. I always get back off the gas when it happens, so I could just be saving my trans from a premature death by paying attention to what is going on with the lock/unlocking the converter, shifts, popping in/out of O/D. Given that both vehicles do the same thing, I think it's something that probably happens across this vehicle generation. It will be interesting to see if anyone else queues in on that trans behavior.
that's funny my 2003 Silverado every once in a while makes a sound like a food disposal is a eating a fork and it makes a grinding noise in 1st gear, stop put it in park, shut off the motor, restart put it in drive off she goes again, its been doing that for over a year drove it all over California as well just waiting for it to finally die so I can just replace it but the dam thing keeps going and going like the energizer bunny.
rockola1971
And you believe with all those awesome sound effects happening right underneath you that your tranmission isnt slowly destroying itself? That grinding is probably a drum rubbing into the case or planetary chewing up pieces of your internals.
rockola1971
Ive owned and worked on more TH700R4/4l60e than you have fingers and toes...in your whole family. None of the 4 current 4L60E that I own do that or have done that and one of them has 275k on the case and 150k on the rebuild. All 4wd/AWD from 99 to 05.
yes I know it is, I'm just waiting for it to finally kick the bucket so I can put in another one, I am not going to pull it out and have it fixed or replaced until it just stops moving, price will be the same regardless may as well get all I can out of it. im hoping it might just make it another year and half so I can just sell it and get my nnbs 6.2l the 5.3 is a dog to me now, ive been spoiled lol
mattt
Okay, you got me there. It must be something about how I drive that both transmissions have exhibited the same behavior with high mileage. Where are you located? Do you do rebuilds? What does it run, or if you don't what should it run on average, for a freshen up on an '04?
Marshall206
one of our work trucks is a 96 express van with a vortec not sure exactly which tranny it has/had... tranny went out at 90,000 original miles but it hauls a heavier load daily and the tranny was over 20yrs old
we had it rebuilt since switching all the equipment mounted in that trucks is a pain. The shop rebuilt it for $3200 but did a HD rebuild, now when you move the gear shifter its really strong feeling like my F450 Super Duty was. The shifter doesnt just glide but you really feel it
rockola1971
Ive been out of the for a living rebuilds for awhile now. I just dont have the time anymore because of work on my land, house, garage, etc. Trasmission shop prices vary by a large margin across the U.S. A typical rebuild of the 4L60e in my area (West-Central Indiana) which includes removal and replace and a better than OEM build with all valve body updates and heavy duty clutch kits with steels runs around $1300-1600 and can go up substantially if major hard internal parts need to be replaced like the planetary. Ive seen many times over where it is cheaper in many places of the U.S. to just buy online and install yourself.
The above $3200 rebuild bill mentioned is just ridiculous. That was highway robbery.
mattt
Thank you for weighing in from the perspective of someone in the know. I thought 3200 sounded like a lot. I am in CA, so I suppose the price will be higher, given that everything costs more here. I have also been told by a longtime Chevy line mechanic that there is something about 2nd gear that the aftermarket has a stronger than factory part, but the details escape me. How far and long is it safe to push a high mileage trans that is still functioning correctly? I do notice that when I do the pan fluid swap, shift quality improves. That leads me to believe the trans isn't quite ready for a rebuild. Thanks again for the insight.
TwiztidPixel
Anderson, SC
Mine has been fantastic so far, but I got a really well cared for Tahoe with paperwork. I'm only at 150k though lol. Question, will any 4L60E work in the Tahoe? I was looking for a "built" tranny and it seems like they were listed for Firebirds etc.
NYRmike
175k on a 2006 5.3l Tahoe LT. Still singin' a pretty tune. I get a T-Tech flush and fluid change once a year, and all is well. I try hard not to drive it like a pissed off teenager and always give it a couple mins to warm up if it's freezing out, and take her real easy the first 15 minutes or so of the drive. Haven't put any snake oil in yet, lucas, marvel, royal purple, etc but have been thinking about it lately, considering how old it's getting.
1948Buickroadie
