Won’t start when colder than 25 degrees
Scottydoggs
NJ
i had to do a intake gasket because i had a knock sensor code, rear sensor was full of water.
its best to remove the foam if you have it front and back of the intake then dry the sensor holes and replace them, also might want to replace that dumb harness to them as well, its gets all beat up and brittle, then rtv the foam caps in place.
D is for DENALI
I understand, the cenex by me has 93 for that price...
I didn't intend for posters to read it as a sams fuel, just that the cheapest 93 top tier is 2.67...,:cool:
There's a Mobil in the next town over with 93 @ $2.86 a gallon last night. Ethanol is down to $1.94 a gallon. Looks like even down here they switched to a winter blend as my alcohol content is 54% according to the Tech2 on the truck's second tank of E85 since switching over.
PG01
Up here to the right
3 and change for 93 here..sunoco
Edit: i still get it
HeavyHoe03
