iPhone 8 wireless charging
Demer
Eagle, ID
Yours works ? all the time ? i have a 2016 Denali what did you do exactly i have removed the magnet only and it worked for about ten minutes and after that nothing did it about a week ago too
So far it has worked exactly I would have expected it to from the factory. I had about an hour drive last night last night, with the iPhone constantly being picked up, used, and placed back on the charging pad. It worked the entire time.
All I did was remove the entire module from the truck, took out just the magnet from the module, and then replaced the module (sans magnet) back in the truck.
Like I said, I only have an hour of drive time so far, maybe it'll take more time before it stops working. I'll make an update if/when it no longer works.
WestTxFrog
Same with me. I removed the magnet only and it worked for ten minutes so I put all back together and then it never worked again. I have a 2015 Tahoe.
chicagofan00
Arizona
So far mine has worked without any issues after removing only the magnet. I did notice though that it will only work if I put the phone with the top of the phone pointing towards the back of the truck. If I put the phone down with the top of the phone pointing towards the front of the truck, it won't work.
DenaliBQ
so are you saying i have to put another magnet back to make this work or just leave the magnet out and i should be fine? I just took the magnet out and it doesn't work
Justinj360
Wait, so the wireless charging works fine with current Samsungs and my Microsoft phone that came out 3 years ago, but it won't work with the current and previous generation of iPhones? Good one (again) Apple.
L's Truck
DC Metro
My Note 8 doesn't charge. I'll have to do some searching.
TechSupport
15-17 GM Vehicles with wireless charging don’t fully support the Qi standards. Do the mod, by removing the magnet and your Note 8 S8 iPhone 8 or X will charge just fine.
MainahBob
I own a 16 LT Hoe-first American car I have owned since 1975. Bought this for a few reasons but one of them was the wireless charging. Went to the dealer last week for an oil change and complained that this wireless charger did not conform to the Qi specs. They tested it with a Samsung phone said it worked fine. Called GM warranty folks yesterday and they seemed interested but non-committal so I doubt they are going to do anything about it. I saw this fix on this forum and Youtube and I pulled the magnet out and then tried (with and without the flimsy circuit board under the coil) but nothing-although at one point for a brief second, I had a RED lightning bolt. (Not sure what that means)
Am now looking at another alternative-Crutchfield sells the Brandmotion FDMC 1273 which is designed to fit in the existing cutout. It is $199 and there is only one review so I am skeptical but still interested.
Anyone have any other thoughts?
willb
