TwiztidPixel
Anderson, SC
I'm needing brakes soon myself. What's 5deal with the platinum pro pads?
I bought them because they were available locally, didn't seem absolute bargain bin and had good reviews, that's about all. I had originally bought the Power Stop pads to go along with the rotors until I saw corvette744's thread. I am very happy with Wearevers though. Nothing to complain about with the rotors either.
Went outside this morning to take the cluster out. Checked first before removing it and it works now! As @Galante stated, probably is a bad ground somewhere, but as usuals, I don't have time.
I also added 1 qt of oil because it was low.
HAPPY THANKSGIVING EVERYONE!!:)
No wonder that cluster keeps quitting if it's losing it's oil. I never have to add oil to my cluster.
MINIz guy
Boy it's been a long day...
Replaced intake manifold gaskets and knock sensors. However, broke the EGR bolts off at the exhaust manifold. The A/C compressor line is conveniently in the way so I can't get a drill straight enough to drill out the bolts.
Going to Home Depot tomorrow to buy a right angle drill and hopefully that will work. Anybody else run into this predicament? Need the vehicle running on Friday and this is the only thing holding me up.
95escahoe
Haven’t posted in awhile but done a few things to the Escalade recently.
Replaced the wiper cowl, LH end cap & wiper arms
Installed Rockford Fosgate speakers in each door
Got the RH side door panels back on and added the gray trim along the top of the doors off an 03 EXT (it’s usually black) installed the missing woodgrain on the rear door still need to do the LH side
After replacing the drivers door I realized the front edge of the rear door was dented so picked up a door from the junkyard and threw it on I’ll see how they both look after a good buff & wax might get them painted, all that’s really left body wise now is a new front bumper, either a new or used driver side running board (it’s dented) and to cut out the rust that’s starting on the rockers on either side it’s just surface rust currently but want to stop it before it gets worse
I did the EGR delete on mine and the same thing happened. I ended up discharging my ac and removing the line since I had a leaking Schrader valve on the high side that I needed to replace anyway. I drilled and re-tapped the old stud. Probably no help unless you want to recharge your ac.
00chevyHd
Bought me A Master Drill Polisher And Polished my Mirrors It Looks Better Than Before Then I Vacumed it Almost Every Single Spot lol Tooked me about 4 hours here and there lol
So much stuff! Nice work.
TM98
Which wiper arms did you go with? My passenger one is not spraying correctly.
MINIz guy
Yea that's what I'm trying to avoid. I have faith since there should be plenty of room with a smaller drill. I just hope my drill bits aren't too dull and I can make quick work of it.
ASG-MikeS
