Vanquish Auto 80w PHILIPS LED Fog Light Bulbs PSX26W Review
phantasms
Brewster, NY
Hey guys. It seems Vanquish must have updated their site or something as almost none of the links here seem to be working. I'm looking for the brightest for lights that will work on my 16' LTZ. All other lights are stock right now so I'd like to match the color temp.
Are these the ones?.... https://vanquishauto.com/super-brig...ment-pwy26w-led-super-bright-replacement.html LED 12000 Lumens in 5000k ?
p.s. as long as I'm ordering are our brake lights LED or no? I see they have red LEDs for the rear. Here's what comes up when I put the car detail in...
https://vanquishauto.com/2016-chevrolet-tahoe-all-type.html
I'm open to other options if there's something better but from my small amount of searching this forum these seem like the way to go, no? Not blinding others is important to me.
Thanks!
Best,
Gene
Unit171
NC
Your link is the correct fog lights for the 16 LTZ as you asked. I too am looking at the same ones. About to hit the buy button
gat0r
DFW
i believe the 12k lumen are brightest... they also have 6000k for more white light.
send them a PM, they will get you the info you need
Unit171
NC
Hello everyone, if you have a 2015 2016 OR 2017 GMC Yukon DENALI and you are looking to upgrade your lights to leds or hids and you want all to match in color, here is the link. These are all PLUG AND PLAY lights, direct fit, NO ERROR MESSAGE-NO FLICKERING
FOG LIGHTS
https://vanquishauto.com/super-bright-led-fog-light-bulb-front-replacement-pwy26w.html
HEADLIGHTS LOW BEAMS
https://vanquishauto.com/headlight-bulb-low-beam-h11-3018.html
HEADLIGHTS HIGH BEAMS
https://vanquishauto.com/headlight-bulb-high-beam-9078.html
IF YOU HAVE ANY QUESTIONS ABOUT OUR PRODUCTS, PLEASE GO INTO THE LIVE CHAT AND CONTACT US OR EMAIL US, THANKS
Unit171
NC
Sorry, that was GMC. Here is the Tahoe links for ours
If you have a 2015, 2016 OR 2017 Chevrolet TAHOE and you are looking to upgrade your halogen lights to LEDS or HIDS., here are the links for the right items your vehicle need. Vanquishauto.com lights are 100% error free, no error message, no flickering and is also 100% DIRECT FITMENT-PLUG AND PLAY.
FOG LIGHTS
HIGH BEAMS
If you guys have any questions, please contact me here, go to the live chat or email us, thanks
Unit171
NC
Okay those links are dead. Ill stop trying to help. Haha Bedtime
affliction4
Thanks!
Best,
Gene
Gene both links you provided are correct. The bulbs themselves are not led from GM, however there is an outer ring that i think is led, but you should be fine with those. Those are the same fog lights I have and they are awesome!
affliction4
Also yes the 5000k will be the closest match to the factory temp color.
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
Vanquish Auto
This review will compare the Vanquish Auto 50w CREE LED Fog Lights ($39.99) versus the NEW Vanquish Auto 80w PHILIPS LED Fog Lights ($119.99).
(You can see my review of the Vanquish Auto 50w CREE LED Fog Lights versus stock 25w halogen bulbs here: http://www.tahoeyukonforum.com/thre...cree-led-fog-light-bulbs-psx26w-review.85767/)
The 50w CREE LED lights consist of 10 x 5w LEDS (2 on each of 4 sides and 2 on end). The 80w PHILIPS LED lights consist of 8 x 10w LEDS (4 on each of 2 sides). See photos below for comparison.
Conclusion: Installation of both lighting options is quite easy. Most people will not find the need to remove any parts other than to just swap out the lights. There isn't a ton of space to work with but it can be done, see alternative installation options below. The only additional step required when installing the 80w lights over the 50w is that you will need to secure the 80w LED controller so that it does not move around, see details below. The 80w lights are significantly brighter and are made almost completely of aluminum to help dissipate any heat. Even though the 80w lights are brighter, they will also be less intrusive/blinding to oncoming traffic due to the LED orientation within the lamp, see details below.
The 80w LED lights have an adjustable heat sink at the base. It allows you to swap the direction of the heat sink to allow it to fit in a variety of locations. This adjustment should NOT be required when installing on any 2015-2017 Tahoe/Yukon. I do recommend you tighten the heat-sink screw (requires a 1.5mm allen/hex wrench, which is included) prior to installing the lights so that it does not loosen when installing or over time.
If you have the $119.99 to spend the Vanquish Auto 80w PHILIPS LED Fog Lights are a great product. If they are out of your budget I still highly recommend the Vanquish Auto 50w CREE LED Fog Lights. Either way you go you'll get Vanquish Auto's 3 year warranty, which is better than most other options out there.
Un-boxing photos
Vanquish Auto 50w Versus 80w
NEW LINK BELLOW
http://www.tahoeyukonforum.com/thre...00-lms-philips-led-fog-light-new-links.98483/
I can NOT give these guys at vanquish auto a good review
I ordered a set of fogs, they sent the wrong bulbs in the correctly labeled box
I sent an email and did not hear back
I also left three voice mails in the past week and have still not heard back.
I'm passing disappointed and moving to angry.
quality appears to be good, but customer service is HORRIBLE
Vanquish Auto
Hello, hope you are doing great. Sorry to hear that but we have been trying to get back to our customers in time. May I have your full name or email so I check on that for you please? Hope you allow me to do that since I'm here to help, thanks
Hodmjstone
