Tahoe is dead, electrically
RealTahoeSS
hello. I have a 2001 Tahoe SS. It died the other day. After turning off the engine a noise came from the dash, then everything went dead. I disconnected the battery worried about a fire. I’ve traced out the positive and negative battery cables; found no problems. I started taking the dash apart on the drivers side. I’m not sure where the body control module is located. I’ve tested every fuse. The 10 amp under the hood labeled “TRL B/U” is blown. It says it’s for the bcm. Could use some direction to correctly troubleshoot. Thanks for any help.
That fuse is for your back up lamps trailer wiring. I think the BCM on those is under the driver's side dash towards the left above the pedals. There should be a couple of modules there so read them.
bottomline2000
Dallas, TX
check the ground wire on the firewall running to the back of the engine. its on the drivers side and your hood light may share this ground.
RealTahoeSS
RealTahoeSS
Thanks. That was the first thing I checked. All the ground connections are good.
RealTahoeSS
RealTahoeSS
Thanks. Found modules, still couldn’t find the bcm.
RealTahoeSS
RealTahoeSS
Yes I know it’s a module. I found other ones, not the one I’m looking for. Thank you
this should be where it is, at least that's what your looking for, top dead center in photo with black squares printed on it, I sold my 2000 yukon but this photo is from a 2003 silvy should be in the same spot. but could be to the right in front of center console or could be to the left on firewall also.
https://i0.wp.com/104.197.77.209/wp-content/uploads/2011/02/DSC04776.jpg
RealTahoeSS
RealTahoeSS
Thanks. I found that. It only has 3 plugs on it. I was told it has seven connections. Obviously bad info. On my end.
rockola1971
Indiana (formerly IL)
6point2lovelifers
