esky running boards
cmc76
So i bought a set of 00-06 running boards. need to pain the plastic ends to match.
on each one there is like a plastic dog ear bracket. really flimsy, and they all are broken.
is it worth trying to plastic weld or reinforce. or is there a reasonable source for those pieces to just use new?
adventurenali92
Big Bear Lake, ca
I’ve seen those end pieces being sold on eBay by themselves. I would imagine they would be in good condition. But that’s to look in to I guess. Lol. I’m curious as to looking into possibly swapping my Denali running boards to esky running boards because I think they look 100x better then my denalis boards. Lol.
cmc76
cmc76
i think i am going to repair and hopefully improve the supports they have. but i have some work to do. I need to remove all the lower z71 moulding to mount these, and im not sure how they are going to bolt up either.
when i repair and paint, ill get some pics together.
adventurenali92
Big Bear Lake, ca
Sweet! I’m looking forward to seeing your work! I think to make them work on my Denali, I’ll have to take the esky pieces off the ends of the board, and swap in my denalis end cap pieces. Because I think the caddy pieces might not mount up correctly to where it meets the Denali lower cladding. So I’ll be interested to see how it works on your tahoe.
cmc76
cmc76
First discovery. The bolts on the bottom to disassemble are likely to be froze in their clips. And most the stuff is plastic. So far plastic welding is holding better than even jb weld. Pics tomorrow
HiHoeSilver
Away!
Chicago
Did you take the Z71 trim off yet? I know it is hiding the mounting points for the nerf bars, wondering what you found...
cmc76
cmc76
havent gotten that far yet. I am expecting some surface rust bare minimum and i just didnt get to it before the temps dropped.
If i can get some inside space for a few days, i will be pulling it once the esky steps are done.
HiHoeSilver
Away!
Chicago
I think you'll find that the rockers don't go straight across, there's gaps where the steps mount. It looks funny. There are pics somewhere....
cmc76
cmc76
Do you think I should keep the z71 moulding and colormatch?
My goal is a lower profile step. But I don't want it to look like a hatchet job.
HiHoeSilver
Away!
Chicago
This is all from my memory, but if you search around a bit you can probably find what I'm talking about. If you're gonna CM, you'd probably take it off to do it anyways, and you could see what it looks like. Iirc, people that have removed it have realized that because of how the nerf bars are mounted, you gotta keep the trim.
DenaliNebakenzer
I actually just went through this a week or so ago. I used some thin aluminum and JB welded the brackets back on and they're holding great. The body shop did a great job painting everything. I also got the roof rack. I'd say it's worth it to just repair them yourself. Where did you get your escalade brackets from so that the running boards fit your truck?
cmc76
cmc76
Good question. I didn't get the brackets.
Can I see a pic of yours?
DenaliNebakenzer
Unfortunately, I didn't receive the brackets. Now I'm trying to find them. So I have a pair of beautifully redone running boards that I can't mount.
cmc76
cmc76
i found a few places that sell them online, ranging from $30-50 a piece?
Really pricey for a small stamped thing.
I have my paint done. Once I get everything put back together i may start looking into making my own brackets.
Drewphil
