Transmission cooler
ridewot
ct
Have a 2008 Tahoe 5.3 motor and I am looking for a good transmission cooler . I pull a 20ft trailer total weight is about 3800 lbs
Hayden and Derale make good ones. I've used both for thirty years with the former and just a few with the latter, no complaints.
ridewot
ridewot
ct
Are they easy to install? Do the fittings come with the kit?
You'd have to look at whether there is a kit or a just a cooler. In the old days we just cut a line going to the radiator and spliced the cooler into that. So all we needed was some clamps and hose. My Derale came with clamps, hose and fittings to mount it against the condenser. I bought a separate fitting that plugged into the radiator so no lines would get cut.
Bought the last few Derales from etrailer and the separate fitting from ebay as they were out of stock at the time.
dbbd1
...the separate fitting from ebay as they were out of stock at the time.
That would be nice! Have to check that out.
dbbd1
'16 Yukon
With the 6L80e trans
Etrailer shows the same derale adapter for yours as well. It goes into the upper port on the radiator, the flared end goes into the hose, the other simply pushes into the fitting on the radiator and is held in with that wire clip. I have never tried to use that adapter on an existing transmission cooler; always the radiator.
dbbd1
Etrailer is where I saw it cross-referenced to the Hayden part number. Oh well, I'll give it a try.
Thanks.
dbbd1
That cross-references to the Hayden 397. I just ordered it (the Hayden) and it's the wrong size. Still try the Derale???
Well, duh! Just call me stupid! The line I kept looking at that goes through the radiator is an OIL line. Not the trans fluid. The Hayden and derale numbers are correct.
Just move along, nothing to see here...
I'll just shut up now...
D Rollins
