Do I really need a new engine?
swingandmiss
First time post. I've been working with our mechanic to chase down an issue with our 2012 Yukon Denali XL. 120,000 miles. Very well cared for truck.
First problem - I was intermittently getting a "service battery charging system" warning. However, the battery light did not go on. I noticed the voltage did vary quite a bit, maybe in the 12-15 range. Never did the battery light come on. Brought it in and my mechanic found the voltage generated was low. Changed the alternator.
This did not solve the problem because two more times got the "service battery charging system" and "service electrical system" warnings. Never did I have any problems turning the truck on. Turned over instantly every time.
Second problem - Turned the truck on one day and got an odd sound immediately. To me, it sounded like a bearing going. And then it went away after idling for a couple minutes. Backed out of the driveway, gave it some gas and the truck started shuttering. The "stabilitrak off" and "traction control off" warnings came on, then "service electrical system" warning. All warnings lasted about 3-4 seconds and then back to normal. Truck had little power and felt/sounded like it was misfiring. The dash also blinked off and then back on. Towed the truck in to the shop. 4 or 5 error codes, non related per my mechanic. Figured it had to be the computer as it's the only thing that connects to all the systems. Replaced the computer and programmed.
Over the next 24 hours, the truck turned off once at a stop light and then got another "service electrical system" when idling. Voltage remained at 14.5 during the warning. No other lights.
Third problem - Brought it back to the mechanic and they found a lose cable to the alternator. Said they could wiggle the cable and the low voltage warning would pop up every time. Replaced cable.
Fourth problem - The very next day, after a day of driving perfectly, driving onto the freeway onramp got the "traction control off" and "stabilitrack off" warnings at the same time the truck started misfiring. Warnings stayed on for 3-4 seconds. This time the check engine light was on and then back off, even before the other two went away. No power, even though the engine seemed to be revving fine. Close to the shop, so drove it back carefully. The engine knocking sound was back the entire time. I also had another rattle that sounded like what a loose exhaust would sound like. Metal banging on metal. But only once I hit 1500rpm. Under 1500 and it generally didn't make the sound. Not completely consistent though. Dash went blank for about 10-15 seconds on the way over. Got to the shop and had them check the codes without turning off. The knocking sound was there, but the metal on metal one was not. We couldn't get that one to come back. But it was down on power and not driving well. Center console also flashed blank for a second.
After 4 days of diagnosing, they say it's something in the engine. The sound is coming from the bottom end. Maybe a stuck lifter. They say the oil smells burned and they just changed it the week before. Also, long history of cylinder 6 misfires. Says needs a new engine. I keep thinking that there is something related between all the problems. They are saying all individual problems. I'm having a real hard time believing this is the case due to the timing. I am ok replacing the engine if it needs to be replaced. But I don't want to replace the engine if something is the problem, or if something else caused the problem. I am hoping the wisdom of the internet can help.
The bottom end generally refers to the crankshaft and its associated components like the connecting rods and pistons and all the related bearings and such. A lifter is part of the valve train or the top half of the motor.
Car guys should know this and if this is what your mechanic said I would be suspicious of his abilities and intentions.
S
swingandmiss
It's possible I've confused some of the details. This mechanic is a friend of the family and we've been using his well known shop for decades. He generally loses money on the jobs he does for us. There are no foul intentions.
Any ideas on what possibly could be wrong with the truck?
2011SSVHOE
I'm an egual oportunity offender
The Heart of The Triad, North Carolina
I wouldn't trash the engine yet. It would be more of a constant knock. just my 2 cents, also a trashed engine isn't going to turn lights on, on the dash, except low oil pressure.
M3kanic
Does the truck rev fine in park but as soon as you go down the road act up?
S
swingandmiss
You have grounding or electrical problems, does not sound mechanical (top or bottom end) to me.
That's what I've been thinking, but can that cause permanent damage to the engine? Why the new oil smelling burnt and obvious knocking.
It was constant the last time it happened. Drove it for about 20 minutes over to the shop and it was there the entire time. I never got a low oil pressure light, but I did notice the oil gauge go down. The dash, yeah, that's one of the things that makes me believe it's not, or not just, a trashed engine.
It drives perfectly when it's not acting up. Between the two episodes it drove like it always does. When it did act up, it sounded fine revving, except the knocking. But in drive no power.
ezstriper
Yes, killed a lifter, going to need cam, lifters, valley cover(has all the controls for the lifters, I would replace the timing chain and oil pump as you will have them off with cam change
EfrainlCazares
I had an episode similar to yours when I first bought my 11 Yukon denali . Came to a stop light and as it turned green and I accelerated, it started sputtering and the stability *** all those lights came on. Pulled over, shut truck off, restarted and it went away, took to dealer since I handnt even paid my first payment. They diagnosed it, bad cam, left side of block, they replaced both came and haven't had any issues since
Danny3737
It never hurts to have another mechanic check it out.
There's only one cam and it's in the center of the block. Maybe you meant lifter(s)?
S
swingandmiss
Brought the truck to GMC for diagnostics. They feel it's a stuck lifter and potentially damaged camshaft. The tech initially said the electrical issues and lifter issue are not related. Coincidence. But he also said he hadn't looked at the electrical systems. When I pressed him on the timing of the problems, and that coincidence wouldn't happen multiple times, he started to backtrack. However, he couldn't explain how an electrical problem would cause the mechanical problem. I explained how I don't want to fix a mechanical problem if there is still an electrical problem which caused it in the first place. I don't want to pay for an engine and then have it ruined because of an electrical problem. And if I did, would they warranty the engine? That's when he suggested he dig into the electrical issues.
He did mention something that I wanted to verify. He said when the variable cylinders are deactivated, the oil sent is also deactivated. He said it would be conceivable the oil stayed off while the cylinder was still on, causing no lubrication to the lifter. However, he said while the control of this is electrical, if it fails, it fails to a default state that sends oil all the time. So there is no way this could cause the problem. But is it?
I don't know how much longer I am going to keep this truck. It already has 120k miles on it and wear and tear from kids.
Option 1 - Repair lifter at about $2500 or lifter/camshaft at about $4500
Option 2 - Replace engine (and other assorted goodies) at about $8000
I'm not willing to do either until I get someone to guarantee the problem won't return if it's a pre-existing electrical issue.
S
swingandmiss
Oh, the other thing that stumped the GMC mechanic is the fact that it knocked, then ran perfectly fine for a week, then knocked again. He was initially explaining that once this starts, it doesn't go away. I explained that it did and he couldn't explain it.
varminpoolteam
