2003 Yukon Where Is My Coolant Going?!?!?
PJS3
If I were not already bald, I'd be pulling my hair out at this point.
2003 Yukon SLT 2WD
295K miles
I have been dealing with a coolant leak / disappearing coolant since winter 2016. I found that the heater hose connector was leaking coolant there. It is notorious for happening after a while. I swapped both the black and the white one out. All seemed to be well. The replacement failed in fabulous fashion (ie. the leak was even worse this time!) in about 3 or 4 months. I've replaced it again. Seems to be going strong. No leaking.
However, my coolant was still disappearing slowly but surely! I have seen no leaks or puddles. Could not figure it out.
I did not smell any coolant in the exhaust. This past week I did begin to smell coolant from the engine bay.
My mind went straight to "it must be the water pump.". Afterall, it's the original, and it just seemed to make sense. So I swapped out the water pump last week right before going on a 450+ mile trip. I get to my destination and I get a "Low Coolant Level" error on the dash. I checked the connections to the new water pump for leaks. Nothing. I checked the reservoir tank for leaks. Nothing. I did not tear the panels and covers off yet to get back into the engine to take a close look at the gaskets for the water pump yet, but from what I can see they seems to be fine. I torqued the mounting bolts for the pump to 22Ft-lbs. Smh.... I'm at a loss here.
Has anybody experienced this that can offer some insight as to what is going wrong here?
P
PJS3
Here's the heater hose connecters I replaced.
Here's the old original water pump.
Heres' the new. I did not replace the thermostat as I had purchased the wrong one. The one I need is the thermostat and the whole housing there. Yes, I know I gotta go back in, but it was a last minute discovery that I did not have the option to rectify immediately. I don't see any leaks from there though.
P
PJS3
Nah, never had the oil tested. I will look into that. But no, the oil is still just a black as usual when I change it. Been running Mobil 1 full syn 5W30 since I've had the vehicle. I got it with 54K on the clock back in 2006. She's been good to us.
sefiro
Pressure test the coolant system (parts house rental tool). You can also get a liquid to mix with coolant to see if exhaust gasses are in the coolant (HG issue). Be sure to run the vehicle for a while and them sample the coolant)
Sent from my XT1053 using Tapatalk
P
PJS3
In my search on the topic, I think my problem could be that I did not burp the system. Like I said... the coolant is literally "disappearing" ... no puddles, no visible path of discharge anywhere.... no smell from the exhaust. I will attempt to burp it properly this evening to see if that makes a difference.
M1Gunner
Gainesville, Fl
One of two things is the culprit. Either you have the heads that with this amount of age develop hairline fractures and the coolant loss is there OR like you said, you did not bleed the cooling system properly. (This is more than likely the case since you did not complain of coolant lose before the initial leaks)
snag a funnel with adapters from a local auto store and attach it to the res. and properly bleed the system.
chevync
North Carolina
Check your heads, see if you have 706. If so Google castech heads. These heads are known to spring a leak around the oil jets. I had a bad set on my old Tahoe.
mbp1979
North Little Rock
I had the same issues ur having and It was a hairline crack in the passenger side head in the very front. Look under ur oil fill cap what's it look like?
P
PJS3
Thanks for all the great replies! Yesterday I went home and properly burped the system based on information I got from another thread.
This morning my wife too the Kon out and came back. Now, based on how it was acting over the weekend the coolant fill level in the reservoir/tank should have dropped below the cold fill mark as though on it's way to giving me another "LOW COOLANT LEVEL" error again. However, it was still at just 1/2" over the fill mark. So that's promising. We'll keep monitoring it over the rest of the week, but this is already an improvement.
God knows I hope the whole hairline cracks and such are NOT my issue...
Now on to the next development.... Smh. My hi beams and my hazard lights have stopped working suddenly. smh...:think::think::think:
Here's the method I used to burp it the system by the way. Review and comment please.
"12 To refill the system, install the thermostat and reconnect any radiator hoses.
13 Place the heater temperature control in the maximum heat position.
14 Be sure to use the proper coolant listed in this Chapter's Specifications. Slowly fill the surge tank with the recommended mixture of antifreeze and water to the FILL COLD mark.
15 With the surge tank cap off, start the engine and let it idle for about a minute.
16 Install the cap on the surge tank, but don't tighten it down (pressure must be able to escape). Raise the engine speed to approximately 3000 rpm in 30-second cycles until the engine reaches normal operating temperature and the thermostat opens.
17 Turn the engine off and remove the surge tank cap. If there is any hissing noise coming-from the tank, wait until it stops then remove the cap.
18 Start the engine and let it idle for one minute. Add coolant to the tank until the level is 1/2-inch above the FILL COLD mark, repeat Step 16, then turn the engine off.
19 Add coolant as necessary to bring the level to 1/2-inch above the FILL COLD mark on the tank. Install the surge tank cap securely.
20 Check the cooling system for leaks."
Marinevet
Can I ask what coolant you all are running? I keep hearing nothing but bad things about the Dexcool that my Denali has in it now, and it's due for a change anyways probably. Did you guys go back to the regular green antifreeze, or stay with the dex cool? Thanks.
Jeremy
P
PJS3
I've just stuck with the dexcool all these years.
sparkvark
South Carolina
The 5.3L has a know issue where you can get unexplained coolant loss. Have you tried the coolant tablets that your GM dealer sells. They are a stock GM product that I believe is vegetable based. I had this problem and my neighbor who is a retired GM mechanic told me to try this. It solved my problem. Only use the GM product. The aftermarket stuff can gum up your cooling system. Good luck.
Rhonda7693
Same issue. Cracked heads. There is a tsb.
#06-06-01-019B: Information on Gradual Coolant Loss Over Time with No Evidence of Leak Found - (Jun 12, 2007)
Subject: Information on Gradual Coolant Loss Over Time With No Evidence of Leak Found
Models: 2004-2006 Buick Rainier
2001-2006 Cadillac Escalade Models
2001-2006 Chevrolet Avalanche, Blazer, Silverado, Suburban, Tahoe, TrailBlazer Models
2001-2006 GMC Envoy, Jimmy, Sierra, Yukon Models
2001-2004 Oldsmobile Bravada
2005-2006 Saab 9-7X
with 4.8L or 5.3L VORTEC® GEN III, GEN IV V8 Engine (VINs V, T, M, B, Z -- RPOs LR4, LM7, LH6, L33, L59)
This bulletin is being revised to include engine RPO L59. Please discard Corporate Bulletin Number 06-06-01-019A (Section 06 - Engine/Propulsion System).
Some vehicles may experience a gradual coolant loss over time. A very low percentage of cylinder head(s) manufactured with an embossed Castech logo may develop a porosity crack in a very specific area.
Inspect the cylinder head assembly to determine if the casting was manufactured by Castech. This can be accomplished by inspecting for their casting logo located on top of the intake port, under the rocker arm support rail and in the spring deck cavity portion of the cylinder head.
Important: If the cylinder head(s) are Not a Castech casting, follow normal diagnostic procedures in SI to determine the cause of the coolant loss.
Mr. Krispy
Sun City West, AZ
Or just keep an eye on the overflow bucket and refill a few times until it quits "losing" coolant. It's actually just burping itself slowly. I had to add coolant to mine 3 times and since then it has been fine.
P
PJS3
SMH...... I finally took the truck to the dealer and had them run a diagnostic. They pressure tested the system and determined that there is a leak into the passenger side cylinders.
I need a new engine, right?
P
PJS3
Forgive me if this is an obvious question, but what can I do with this information? With it being a TSB does that somehow cover under a recall or a warranty or something?
MidwestMike
Southwest Michigan
No recall or warranty.
GM knows that they have a common problem, but aren't covering it, just giving their techs information on how to save time fixing known issues that they sold.
There was one Castech head number that is predominate in this issue, but it has been known to occur in a few other runs.
P
PJS3
Welp.... So ends the effort for this vehicle. 296K miles, 11 years.... $23,000 invested total.... Not bad. I'm satisfied.
Thanks folks!
MidwestMike
Southwest Michigan
But a stupid way to lose it, the luck of the draw. If you didn't get one that they built with the bad heads you would still be rolling.
HeavyHoe03
