New things every day. Rear spacers
CAMcvicker
So yesterday I figured out I had bilsteins 5100 all around. And today I look at the rear and it looks like I have maybe a 1.5" spacer. It's at the bottom of the coil spring and is a silver metal appearance. I know he must have aftermarket keys too cause it's pretty close to level. Does anyone know the stock ride height of a 03 z71? I ran across it somewhere before but I can't find it now
C
CAMcvicker
I did some measuring. My rear fenders are at 39 and 3/4s and my front fenders at at 38 even. I would like to get my front two at 40 even if possible
Chiggy
Kansas City, MO
I would believe that if you're sitting that high already that you're maxed out with what you can do with the keys. Next step is either a 6 inch lift or a 1-2" body lift.
01Konvict
Boats n Hoes
Raleigh/SML
You can get your fronts up to 39" but much more than that would be way cranked on the keys. I have a 2" rear spacer and 33s sitting at 40.5 rear and 39.5 front. What tire size do you have?
C
CAMcvicker
I have 285s on it now. I talked to a guy who's front end was at 40 with eBay keys and they weren't maxed. I know I have room to go but I don't readylift keys are indexed to much higher then what they are now.
Chiggy
Kansas City, MO
If you go too high you're putting your CV shafts at too much of an angle. That will wear out the CV joints in a hurry.
C
CAMcvicker
I understand that part of it. It just doesn't make sense that mine is sitting at 38" while others are at 39-41 with keys. I would be happy if it was just leveled but it still has rake
01Konvict
Boats n Hoes
Raleigh/SML
285x??R??, need the whole tire size to factor in fender height with key spacer combo. I would expect you could crank some more on the front but all rides are different. For example my driver key bolt is almost bottomed out and passenger key bolt only half way.
1adam
Are your rear spacers on top or bottom of rear spring? I installed a 3.5 front and 2.5 rear and it feels like it real sensitive driving now. The kit says to put on top but the pic shows it on the bottom so that's where I put I'm confused now. I even got it aligned too same issue. Any help would be great.
01Konvict
Boats n Hoes
Raleigh/SML
Yes spacer goes on bottom of coil spring. Once these are leveled as high as yours they get a little wandering. Get longer sway links for the rear and fronts too. Then adjust jounce stops to just near or touching lower arms. That usually cleans up the ride and if not you could get better sway bars.
1adam
Here is a pic with 20x10 with 33x12.50x20. Totally changed the way it used to look.
1adam
Thanks for the info. Will do.
01Konvict
Boats n Hoes
Raleigh/SML
Sorry confused what years were talking about. Disregard jounce comment. You just need longer sway links and maybe new stiffer sway bars if links don't help. What shocks do you have on it?
1adam
I have the stock ones on...
JeffK
