Does anyone know or have a link on who makes this?
I was looking on eBay, saw some made by duraflex. I'm not sure I'd do it, just looks really good. Got this pic off the forums but the member hasn't been on for a few years.^^^I'm pretty sure that's a modified Silverado SS bumper cover. There are "SS" style covers on eBay (Duraflex) that look similar. There was a Tahoe SS concept that had a cover that looked like that one, but I don't believe it was ever in production. There's a member on YouTube, "Thefabforums" that made an "SS Tahoe" and he says the bumper cover is a factory part. Maybe GM never made the actual Tahoe SS, but offered the appearance parts?
Think so? I read in the description how fiberglass needs a lot of work, sometimes, to get it right. Sometimes needing to add more glass due to fitment issues. Honestly, more work then I'm willing to pay for.That Duraflex one is probably your best option for that. After paint, of course.
Here it is on ebay.
Sounds doable. I'm def gonna keep Duraflex in mind. Thx for your input.I didn't see all that. I knew this contained fiberglass, but nothing like the old school rigid fiberglass parts. Their online videos show a raw/primed product with what looks to have a paint-ready surface.
I found this:
"Duraflex is an FRP (Fiberglass Reinforced Plastic) body kit and aerodynamics product line. The Duraflex product line differs from the competition in the manufacturing techniques and proprietary resin formula that results in a cost effective fiberglass component that is more durable and more flexible than a standard fiberglass component. Duraflex products have been found to have a reduction in shipping damages of up to 75% over the previous standard fiberglass product line that it replaced back in 2005. Duraflex is not perfect and flaw free straight from the box. Duraflex body kits and aerodynamics do require the same installation techniques and paint prep techniques as standard fiberglass body kits. Duraflex parts are not paint ready out of the box and will always require sanding the entire surface and filling any chips, scratches, and spider cracks that may be present in the base primer finish. Duraflex body kits and aero parts should not be compared to urethane products in terms of flexibility. Urethane is much more flexible but also significantly heavier and more expensive to manufacture. Duraflex body kits and aerodynamics are manufactured with the intention of offering a low priced part that has superior quality, styling and durability that will withstand normal daily driving."
Doesn't sound like much more than what's required for prepping any body pieces for paint, unless their product is much worse than what's shown online. All I can say is to search around for reviews on fit and finish out of the box. If it's just filling in small pits/nicks, that can easily be done at home. Then sand it to whatever grit your painter requires and bring it to them. Little stuff like that, your painter may not even bother charging you for it since it's easy and you're a repeat customer.
I number of people have. There's a few threads on here I believe they were using 03+ Silverado fogs an they lined right upi think it looks pretty bad ass. im wondering now if mounting fogs behind the mesh would be doable, and if the light would be garbage .
You'd think the plastic would be easier to crack. I'd think it would like more brittle, especially when it's cold out.From the Info I've gathered there is the duraflex typically cheaper but cracks easier and has more fitment issues.
Then there's the street scene gen 6. Which is plastic. More expensive but. Better quality with a warranty
