02_Tahoe
Maryland
Congrats on graduating! FYI, measure your truck at the bodyline at the front and rear of the doors. The fenders on the SUVs are not even, the rears are lower. Your truck looks great, would hate for you to do all that work and have it have rake when you're done
Sent from my VS990 using Tapatalk
Would it be ok to measure to the bottom of the step at the front and then at the rear?
04Huck
"I'd rather be lucky than good"
Buford, Ga
Yeah, you could do that. When I dropped mine I made sure it was dead level at the body line but the step would work too cuz it's parrallel. IIRC, the rear wheel well is like .5" shorter to the ground than the front
02_Tahoe
Maryland
Thanks for the heads up
HiHoeSilver
Away!
Chicago
They say if you have a job you live, you never work a day in your life. Ok, enough of the old man wisdom. Good luck.
Old man advice comin atcha:
1. Happy wife, happy life, i.e. Don't buy a wife.
2. Always keep a bottle of whiskey in your tool box in case you get hurt before the job is done.
Fillerdust
Omaha
I gave her a well earned hand wash tonight. She definitely needs more squat. I need opinions on what lowering kit I should get.
BADRIDES
I parked mine
Are you happy with the 285-45-22 tires? We have the same drop and I cant decide between 285-45-22 and 305-40-22 tires. I just think the 285's look a little too beefy. But then I'm afraid the 305's will ride rougher cause of the shorter sidewall than the 285 and I might have more fender well space than I want with the 305.
04Huck
Buford, Ga
Ride wise, yes. They ride great. They're just too big, I rub like a mofo up front and I wanna go lower. So I'll be going smaller in the future. I love how wide they are tho, looks beefy
kwOH
Banned
Haven't been able to do much to the Tahoe lately. I had graduation practices, actual graduation, then a camping trip. Now finally back. On Friday I'm getting 20% on the front 2 windows, I also measured my fender heights. 41.25" at the front 40" even at the back. This Sunday in ordering new suspension parts, new upper and lower control arms (with new ball joints and bushings), new camber bolts and camber guide pins, tie rod ends, and new bump stops. Ill be putting the parts on myself and bring the front down so it's 40" to all the fenders, align it enough to get it to a shop to get a professional alignment. Once that's done it should feel much better because right now I'm riding on the droop stops. If I feel like it could be improved I'll get a steering stabilizer.
Unfortunately I also have not been able to do much to my nbs here lately or my nnbs, I was sick as a dog for about 2 weeks, my mom graduated college after going back at age 50 to finish her degree, younger sister graduated high school, my grandfather passed away, and I bought my first house and moved about an hour away. Haven't had time do anything except run them through the touchless car wash and then get them dirty again. Looking forward to getting something going again asap. Might not do much besides some maintenance till I can get to the point where I can trade my nbs tahoe in on a nbs esky lol.
Sent from iPhone 7 plus using Tapatalk Pro
MadDogDelpho
Texcellent
A question to the lifted guys, can you still go through an automatic car wash? Just in case I just want a quick clean and don't feel like doing it myself.
Austinite
Austin, Tx
Most will have a clearance guide hanging down so you can be sure. And make sure your new tow mirrors are gonna clear too.
Merc1973
Maryland
Snapped bolt while changing out AC belt tensioner. Bolt is located in AC compressor bracket. Ordered used (looked new) compressor bracket from ebay. I had to remove the compressor in order to remove the bracket. All went well, shockingly. Even installed new seals to Hi/Lo lines to compressor. Suctioned down and recharged using my Harbor Freight Vacuum Pump and R134a Manifold gauge set. (Totally worth it and It's paid for itself already).
It took a while for the pressures to get to normal, seemed as though there was a blockage as my Hi side pressure went up to 350 at one point. The compressor stopped engaging at one point. I put in about 3.5 cans (supposed to be 44 oz) of Walmart Supertech R134a ($5 each) as per online charts. After cycling on and off and increasing RPM, it's giving me normal-ish readings (Lo 45/Hi 150). I wonder if I have crap in lines? It seems cold, even the rear. Should I have swapped out the Orifice Tube since its so easy to replace? Do the high $ R134a formulations work better with those Additives to make it cooler?
PG01
Up here to the right
Yes on the orifice, any little crap can clog that stupid thing. If its blowing cold leave it now, no additives.....unless its leaking then the leak stop crap but not much.... my 2cts
wwiizz
