Door lock actuator
Larryjb
Given the very few youtube and instructional posts on replacing these, I assume door lock actuators are a relatively rare occurrence. In the one good video I saw, the guy removed all the rods from the door handles first, which involved removing both door handles. This is one reason I waited this long to do the job. I didn't want to have to remove so much stuff.
When I got into it, you don't need to remove door handles at all. You can pop off the rods from the actuator/lock assembly first, then remove the assembly. Then you must remove two small screws that hold the actuator to the lock mechanism, carefully cut and remove the security sensor, and glue it onto the new actuator. Once the glue dries (I used JBWeld), you just screw the lock mechanism to the new actuator, and reinstall it into the door.
If anyone is interested, I took pictures and can post a more clear set of instructions.
ScottyBoy
Shreveport, La
I had the one in my driver's door fail twice. First time it was still under warranty so the dealer replaced it back in 06. Then it went bad again several years later, and I just replaced the entire latch/lock actuator assembly with one from the junkyard that I scored for 25 bucks. It's been working fine ever since.
L
Larryjb
This is for a 2002 Tahoe.
After removing the inside door panel and pulling the rain shield back, this is what you'll see.
1) Using a blade screwdriver, pop out the rod connecting the inside door handle to the lock mechanism circled in red. There is no need to remove the rod from the door handle itself.
2) Using a blade screwdriver again, pop off the rod connecting the inside door lock to mechanism circled in red.
3) Push indicated tab outward until you can release the plastic catch. Careful to not break the plastic. This took two hands. One to push the release tab, a second to pull the catch open.
4) You can now remove the rod connecting the outside door handle to the mechanism.
5) Unbolt the lock mechanism from the side of the door. It is easier to pop off the remaining rod after the door lock mechanism has been unbolted.
Continued next post...
L
Larryjb
6) Remove electrical connectors. There may be two or three.
7) Remove small torx screws.
9) Actuator will begin to fall away from mechanism. However, the sensor is still attached (circled in red).
10) Sensor is now released from mechanism.
11) Actuator rod fits in here, in case you forget how it goes together!
L
Larryjb
12) You must cut along the yellow line with a sharp razor knife so you can move the sensor to the new actuator. This is a lot easier than it seems. Once cut free, clean surfaces with a file, then glue onto the new actuator. I used JBWeld and left it clamped to cure overnight before reinstalling.
13) Installation is pretty much the reverse of this process. The actual work took me a couple of hours, and I work slowly. I'm sure many here could do this in 1/2 hour, not counting the time it takes for the glue to cure.
Remember that your door latch mechanism will not be installed while you're working on it. I installed the door latch overnight while the sensor was curing on the new actuator.
08HoeCD
Door lock actuators are one of the most common failure points in these trucks. The motor is signicantly under-torqued for the actuator cycling over the average life of the vehicle, so they ultimately burn out.
I've replaced two in the past ten months or so. First attempt is moderately challenging but successive efforts are a piece of cake.
L
Larryjb
Door lock actuators are one of the most common failure points in these trucks. ...
When I get a chance I'll take apart the broken one and see if it can be repaired. Aftermarket actuators tend to fail much sooner than OEM, so I either need to know how to fix them, or buy a few future replacements.
L
Larryjb
I buy replacement actuator assemblies from GM Dealers selling on ebay and they cost about $100. Crossing my fingers that they last a few years.
Others, who are far more technically capable and patient than I am, have gone with buying a new motor and tearing into the assembly to replace it:
http://www.gruvenparts.com/2007-2014-gm-door-lock-actuator-repair/
The 2007+ actuators look completely different from the 2000-2006 ones. It's really not bad to change the actuator on the pre 2006 models.
losloho02
