Help... Blower motor or switch?
RicanGM
Fountain, Colorado
I just hit the defrosters...they work better than a wiper that will crap out. GM wipers suck.... and If I remember, they called these "barn doors"
I haven't drove mine in the rain yet, but I will try the defroster to see how it works.
RicanGM
Fountain, Colorado
RicanGM
Fountain, Colorado
Mine has the spoiler looking vents on top of the doors, hopefully is good enough to keep the rear window somewhat clean.
east302
Mississippi
Does the blower motor work on high speed only and none of the lower settings? If so, its the blower motor resistor. Check the motor out like everyone has said and go from there.
Yeah our Hoe's are all kinda close !
Sent from my SAMSUNG-SM-G930A using Tapatalk
Quick sidebar, is that grill guard frame mounted (vs bumper mount) and what do you think of the Mud Terrains?
mtl111
Arkansas
It's frame mounted, although there are 2 small tabs that attach to the top of the bumper. The Mud Terrains are great! I've had several sets through the years on my 4wd's. These are KM2's ,i like them better than the originals.....except for the price!! Lol!
east302
Mississippi
Thanks.
Is that a 99? Nice color combination, kind of wish I had found one like that.
mtl111
Arkansas
Thanks, yes its a 99'.
Scootinz
Scootinz
It's hard to tell in your picture but is your top color pewter?
mtl111
Arkansas
No, its charcoal gray metallic.
east302
Mississippi
What brand grill guards are y'all using?
Back to the original question, here are the blower motor diagnostics for a 1998, hope it helps...
mtl111
Arkansas
The grill/brush guard is a Westin.
east302
Mississippi
Is it their sportsman model?
Are you powering the lights from an aftermarket switch? Some trucks had a factory Auxiliary or fog light switch that fit to the left of the radio. I was thinking of seeing if those could be used.
mtl111
Arkansas
The 2 light's on there are using the switch that came with them. Thats an older pic and I've got 2 smaller PIAA driving lights between them now. Those are hooked up to a factory fog lamp switch in the dash.
dmhscorpio
BC, Canada
I have had experience with this. The blower motor runs through the resistor for the lower speeds. High speed bypasses the resistor via a relay. Often the problem is the motor pulls too much current and melts the plug on the back of the switch. It should pull about 6 amps. The last defective motor I changed was pulling 11.2 amps, which has melted the plug a couple of times until I figured it out. The motor sounded fine, so I assumed it was OK. The resistor had gone previously, which i had changed.
If the fan runs fine on only high, I would check the resistor.
If it intermittently works on the lower speeds, I would check the plug. If it is melted, check the current draw on the fan motor.
I was offered a chinese motor for 40% less than a Delco, but opted for the Delco one. It takes less than 30 minutes to change the fan motor.
dmh
Scootinz
Scootinz
THNAKS! Great help. I was gonna peek at it yesterday but yard work consumed me. Now with the nice weather not much of an issue, but I do plan on ripping into it soon. Thank you for taking the time to post this. This will be really helpful!!! Have a great week!
Scootinz
Scootinz
dmh
Thanks for this info! Haven't dug into it yet. It's on my short list though. I have absolutely nothing no blower at any speed. Checked fuses and relays they were fine. As I mentioned in a previous post it has been intermittent and the fan speed switch felt funky like something possibly broke inside of it. It wasn't very smooth anymore. Or maybe like you said the motor is pulling too much current and melted the switch. Something's up though
Drewphil
