Denali acts as if the battery is dead.
cheebs
I woke this morning and went to start my truck and nothing. No crank no start no power. I turned the key and it blinked like it was going to start then nothing. it's acting as if there is no battery and after turning the key a few times it turned on like there was nothing wrong. The batteries are fine i checked. Yes there are dual batteries. Any ideas?
02_Tahoe
Maryland
So it did start right? Sounds like a bad connection somewhere to me
C
cheebs
It did start. Bad connection? But where could that be to kill all the power? I checked the battery cables.
02_Tahoe
Maryland
Maybe look in that red box with connections in it, follow your positive battery cable to the box, open it up and see if everything is good
02_Tahoe
Maryland
That little red box right next to the alternator in this pic
David Smith
Savannah, GA
Sounds like a bad connection to me as well. Maybe something is corroded or just loose. If you used cheaper cables for your second battery, there could be corrosion inside of the cable itself.
PG01
Up here to the right
Def agree with everyone....
Ground and check cables at starter.
You getting in and moving around, giving it a jolt from turning key a few times, sounds like loose wires...
C
cheebs
Ok the battery and the no crank /start issue don't seem to be related. i went thru and checked the wiring and added a second battery. The truck will not crank and then all of a sudden After a few tries or sitting for a min will crank and start with no issue. Before i replaced the fuel pump i never had this issue. It would crank the starter would turn but no start for two tries and then start on the third. Is it possible i burned the starter with two many cranks when the fuel pump was shot? Or could it be the Ignition switch?
jaywoo65
Cabot, AR
When you turn the key on, is there power in the vehicle? Headlights, horn, etc and just won't crank until you hit the key a few times? If that's the case, it sure sounds to me like a starter solenoid is going out.
C
cheebs
Yep. This.
jaywoo65
Cabot, AR
If it does it pretty much all the time, the next time you go to start it tap it with a hammer or something first. See if it doesn't start right away.
C
cheebs
Better yet I how i figure out which one it is? Starter, Ignition switch or starter solenoid? or just replace them all?
jaywoo65
Cabot, AR
It's most likely the starter solenoid. I don't know if you can change just the solenoid from the starter on these or if they are one unit with the starter itself. Try tapping it with a hammer first.
I would say it's not the ignition switch if your lights and radio dim when you hit the key to start it. That's current draw from the starter. If the ignition switch was flaky the lights and stuff wouldn't dim down.
PG01
Go to passenger side, look thru wheel well towards back, youll see a thick red wire there... eyeball that then go under and take a peek.... 2 bolts holding starter on easy peasy... but check wires there for corrosion, green, nasty battery term looking shit...
M1Gunner
Gainesville, Fl
That is completely inaccurate in reference to the ignition switch.
jaywoo65
Cabot, AR
Feel free to elaborate. Tell me how you will experience current draw from the starter if the ignition switch is faulty and the engine isn't cranking.
yottybaby
