Had the hoe towed home!!
PG01
Up here to the right
Yes you trust it and to prove it drive the balls off it and when you pass an auto parts store stop in and grab a maf sensor and cheap code scanner to keep in the truck as you drive its balls off......just in case.
P0068 is a mis-correlation between the MAF and MAP sensors. Basically, the MAF is saying X amount of air is passing through it for a given amount of time which means the manifold should have X amount of pressure in it based on throttle position, engine load, etc. Anyway, what the MAF was saying and what the MAP was saying didn't correlate. This can cause all the symptoms you had before you parked it and called the tow truck. The fact that it "came and went" says it was either a temporary loss of communication (loose wire connection in power or data circuit) or just a glitch in the PCM (not so likely). Codes don't go away immediately even if the problem seems to have been fixed. There's a certain amount of drive events, called drive cycles, that have to take place with the issue not returning before the code will go away on it's own. A dirty MAF usually causes less-than-optimal engine performance and quirky trans shifting, usually late and/or rough shifts.
If it were me, I'd start it and wiggle the wires around the MAF and MAP sensors. Maybe even give them a SLIGHT tug. Maybe tap them with the handle of a screwdriver. One of the sensors could have a cracked solder joint that opens when heated, so it may be rock-solid until you driven it, then something like a bump in the road sends a slight jolt that causes an open circuit for a split-second and triggers the lights and Reduced Engine Power mode. I'm leaning more towards a MAF issue over the MAP.
2011SSVHOE
2011SSVHOE
I'm an egual oportunity offender
The Heart of The Triad, North Carolina
WOW , thanks that's the best explanation I've gotten so far. Haven't found much on the google about it but i'm thinking it relatively simple fix. I think i'm going to drive her to work tomorrow I still have the scan tool and I can clear the code if need be.
I hadn't driven her more than a block when the event happened so she was still cold in my opinion.
Big thanks again Chris!!
No problem.
This scan tool you borrowed- is it just one of those basic pocket "Read/Clear" models or is it an upper-scale model that can display freeze frame data? When a code is set, a freeze frame is stored in the PCM. The freeze frame is a datalog showing what all of the sensors were reporting to the PCM at the time the code was set. If your scanner will show freeze frame data, you can see what the MAF and MAP sensors were telling the PCM at that moment. If one of them is showing something far out of spec, then you can focus your attention towards that sensor and/or it's circuit. FYI: People often are quick to say a sensor is faulty when they get a CEL, partly if not mostly because the parts stores are quick to push sensors onto them. For example, someone's CEL comes on and they go to Vatozone to have the code read. The code says the oxygen sensor is reporting a high or low voltage (rich or lean). Pretty much every time, the parts salesperson is gonna tell them they need a new O2 sensor. This may not necessarily be the case. The O2 sensor could be perfectly fine and was just doing it's job by reporting that the exhaust was rich or lean, which means you need to see why the exhaust was rich or lean- stuck injector, exhaust leak, other sensor reading faulty and making the PCM erroneously over-compensate, etc.
Kenny D
Crosby, Tx
No problem.
Good point.
2011SSVHOE
2011SSVHOE
Chris, the scan tool is an OTC 3109nlaz Auto scanner. I didn't see anything on the menu for the freeze frame event. I drove her to work and back today, the only thing I noticed is the throttle body seems to be slow to return to idle from say 1500 rpm and seems to be downshifting a little odd. that may be due to the slow idle response, kinda like having your foot on the gas when you are trying to stop, if you know what I mean.
According to OTC's site, the 3109N does live data and freeze frame. Next time the light comes on, don't be so quick to clear it. Wait til you get home or parked somewhere you can plug in the scan tool and search through the menu(s) for a freeze frame on the code(s) it retrieves from your PCM. The odd throttle actions could be (and probably are) related to the recent issues. Unplug the MAF and see how it responds. It may seem confused at first, but it should resort to a speed density tune and settle out. Yes, your SES light will be on, but just ignore it for now. If the hanging idle issue goes away, then you're narrowing the problem more towards a fault with the MAF or it's circuit. Since the hanging idle problem seems to have happened after you cleaned the MAF and TB, I'd suggest popping off the intake tube again and checking for any residues. Quite often, someone will clean a TB with a solvent as normal. The solvent loosens the built-up crud and turns it into a liquid that makes it easy to wipe away. It's difficult to see and get to all of the liquefied build-up, so some of it is left behind. It eventually runs down and collects in the bottom of the TB. The car is parked over night, the build up solidifies back into a gummy state, and is now causing the throttle blade to stick (which can't be felt with a DBW setup). But, it could also be acting as a dam to keep the throttle from closing fully and smoothly when you're off the pedal.
2011SSVHOE
2011SSVHOE
yea I was gonna reclean ithe Throttle body this weekend because my first impression was maybe its sticking in the pivot points where it rotates. but what you said makes a heck of a lot more sense,. then I'll try disconnecting the maf. according to OTC website and fleebay that scanner comes with a cd so I guess you could hook up to a PC but autozone didn't provide it. maybe I should just but a good scan tool anyways. thanks again Chris. oh yea I forgot a Buddy of mine at work says I need to spray tb cleaner or carb cleaner around the intake to see if there is a leak. good idea but I don't think that's an issue. any thoughts?
You should be able to read everything you need to see on the scan tool's screen. Usually, those CDs have drivers to interface the scan tool to your computer so you can update the tool's software and print the data from it. Regardless, it's not needed for your purposes.
It's always good to double-check your work. I'd save the carb cleaner for actually cleaning the TB and just visually inspect the intake tract from the MAF to the TB. It's only a few clamps and couplers and it can be easy to not have one slipped on all the way. A leak between the TB and MAF will result in unmetered air entering the engine, and that can cause idle and drivability issues. It can affect the trans shifting because the shift tables are partly determined by engine load, which is determined in part by engine vacuum, which is read by the MAP. So, pop off the intake tube and clean the TB again. Then be extra attentive when reassembling everything. I spray a light squirt of Kroil or WD-40 on the inside of the rubber couplers to help them slide on much more easily.
2011SSVHOE
2011SSVHOE
Ok this morning I re cleaned the tb and the maf. The TB was still somewhat dirty as it was cloudy the other day and hard to see, it's clean now. I drove it around a little, No change, same thing takes a while for idle to settle back down. I unplugged the MAF, it didn't seem to make a huge difference, still slow to return to idle, CEL did not come on, but Service stabilatrac light came on
Oh I did find the freeze frame feature but it was already erased
2011SSVHOE
2011SSVHOE
I've read a few things about the cold air intake tube, how do you check it for leaks?
This is just a picture from google, but if it has an open seam it could probably wreak havoc with drivability. seems like a real stupid design :confused::2cents:
HiHoeSilver
Away!
Chicago
The best way would be to find a brick wall and throw that thing at it as hard as you can. Now your KNOW it leaks, and you can get yourself a decent MIT.
Floep
When I still owned 2009 Hoe, It did exactly the same as your symptoms describe. Long story short eventually after emergency motel stay, the Local dealer came up with a GM recall bulletin to replace throttle sensor, his description. Ran fine after ward and no charge because of recall. No more problems finally sold the vehicle to daughter in law who loves it. I bought a 2014 Yukon and am very satisfied with it
2011SSVHOE
2011SSVHOE
Thanks, it's running good just takes forever for the idle to settle down . I took a video of the tach, but I can't upload because it's a .MOV file I'll check to see if there are any TSB's out there.
2011SSVHOE
2011SSVHOE
Update, I just got home from the Mountains of NC, Round trip about 350 miles The hoe ran fine and is getting an average of 19mpg with a full load, two dogs and running 70-80mph. I still never found a hard fault with the dtc P0068, All I did was clean the throttle body 2 times cleaned the MAF sensor. The weird idle problem went away after I disconnected the battery. I'll keep my fingers crossed and hope that was it. Thanks to all for your input. Later All !!!!
X-ray Nerd
