How to replace your pitman arm
ravingmadman
Chief Knuckle Buster
Greater Seattle
Didn't take pictures because it isn't too hard to explain. I can save you a lot of time with what I learned doing this last night. Shop quote: $350, and a couple hours. My total cost: $20, sore back, an evening under the truck cursing Todd from Burien. Hmmmmm.....
You need:
-Pickle forks; 1" and 1 3/4"
-BFH (I used a framing hammer with mediocre results)
-Metric socket set
-Standard socket set
-Needle nose pliers or a cotter pin puller hook thingy
-Really big crescent wrench; needs to handle 200 ft/lbs, on a ~2" nut (sockets won't fit)
-New Pitman arm ($20 at O'Reilly's)
-Grease gun & lithium grease
-Beer
-Possibly power steering fluid, now is a good time to check it.
Picture of tools (BYOB):
Steps:
  1. Jack up the front end, far enough that the suspension is fully unsprung, and the tires can rotate freely. Put it on jack stands.
  2. Remove the plastic splash guard from the front of the truck, exposing the idler arm on the left, the bottom of the enginein the center, and the steering gear on the right. I tried just letting the guard swivel, and spent toooo much time fighting it. Just remove it.
  3. Turn the wheel (or just push the tires) all the way to the left, which will bring the small end of the pitman arm right to you. Look for the crown nut. Pull the cotter pin, and remove the crown nut.
  4. Use the 1" pickle fork/hammer to separate the pitman arm from the steering linkage. It won't come all the way out yet.
  5. TURN THE WHEELS TO STRAIGHT FORWARD
  6. Using the uber crescent wrench, from the front of the truck, strain your back trying, and then eventually succeeding to get the pitman arm nut off of the bottom of the steering gear box. Beer helps numb the pain. There's a little plastic clip that will be right in your way to piss you off, and it is really difficult to get off. It connects to the front brake lines. Don't waste your time trying to get this thing off.
  7. When you get the pitman arm nut off, use the big pickle fork/hammer to get it loose (it won't come all the way off at this point, no worries).
  8. Remove the three big bolts holding the steering gear box to the frame. The bolts are available from inside the wheel well, go all the way through the frame, and screw into the steering gear box. Do not disconnect any of the power steering lines, or anything else. It isn't necessary.
  9. Push the steering gearbox up, and inward, using the big pickle fork to help separate the pitman arm from the steering gear box. You might have to rotate the steering gear box clockwise as well to get the pitman arm completely off.
  10. Pull the wheels all the way left again, and use the small pickle fork to separate the pitman arm all the way from the linkage. Stand up, look skyward, and hold the removed pitman arm over your head so the steering linkage gods can see your dead sacrifice.
  11. Install the grease fitting on the new pitman arm if you need to, and fill it with grease. You might have a little foam ring, too, it goes on the small end. Slip the small end into the linkage, and put the crown nut on a couple of threads. Slip the big end onto the steering gear box, again, you may need to rotate the steering gear box to get it all together.
  12. Bolt the steering gear box back into place. These bolts torque down to 100 ft/lbs, so put your back into it. Again.
  13. Push the wheels to straight, and slip the pitman arm on. The splines will only match up one way, so fiddle with it until you get it right.
  14. Put the lockwasher and pitman arm nut on, and just about kill yourself getting them good and tight. This torque spec says 186 ft/lbs. Just pull on it until your crescent wrench bends. You'll know you have it right when your knuckles go "clunk" and back goes "bang" with a sharp, burning pain shooting up your neck.
  15. Pull the wheels all the way left, tighten up the crown nut, put a new cotter pin in it.
  16. Since you're down there with a grease gun anyway, lube the upper and lower ball joints and the idler arm.
  17. Drink more beer, call it a night.
Hope that helps someone!!!
:drunk:
GreyFox
Where cars get rusty
Idk. I ' supposed to do this with my buddy. He said its insane to try it like taht so he wants to it by the book.
Raise vehicle and support.
remove nut from Pitman arm
use universal steering linkage puller
Remove power steering gear( from vehicle including disconnecting hoses)
use Pitman arm puller to remove arm from steering gear.
Inspect.
Installation reverse of normal.
Note: I've simplified some of the instructions
Would have had it done sooner but the cross-member is in the way. Even on a lift this thing is a pain to do.
ravingmadman
ravingmadman
Greater Seattle
Inspect.
Did this sequence actually work? I don't have a gear puller, and I didn't want to screw with the flimsy power steering lines. How did you get the pitman arm out of the steering linkage opposite the gear box? I didn't have any clearance, though I tried. If you remove the gearbox, you still have to do everything I've mentioned, but you have to add removal of the power steering lines, removal of the steering linkage to the steering wheel, and you'll want to have a drip pan ready for the power steering fluid that will leak from the gearbox, yes?
GreyFox
Idk haven't tried it yet. I will aasume you would have to prime the system all over again.
An Air hammer coming in from the side will get it loose and BFH will knock it out completely from the center link.
There is a plastic cover on the gearbox when you look under the hood the lines stick out of it. Does that come off easily or No not really?
UPdate: Talked to my buddy he's kinda of uneasy about doing it. He mentioned something about the clockspring (I know there is an evo steering sensor but does it have a clock spring?) becoming damage from hammering upon it the airbag possibly deploying.Due to hammering upon the Steering box. Note $300+ for a local guy to do it but I can't tie up my car for the amount of time he'd take.
riviera rider
the clock spring is in your steering wheel i dont see why it would have anything to do with changing your pitman arms
TigerEyz3
Slow and Steady
TN
No springs involved with changing pitman or idler arms.
IIRC, you don't have to remove the steering gear box either. However, I've got 2wd rather than 4wd which is probably a little easier than a 4wd. Not to hard to get to the idler arm other than the frame on the 2wd.
newmarketeod
Removal of the power steering box isnt too bad. (Im currently on my third trying to get my steering to work correctly) Its 4 bolts on the side through the frame. Remove the nut from the pitman arm on the steering linkage side. Then slide the cover on the box upwards, towards the steering wheel and remove the bolt holding the steering shaft to the box. Then remove the two lines and take the box out.
The issue with the clock spring and removing the power steering box is if while your box is out you spin the steering wheel. Good insurance against this is before you take the truck apart buckle your seatbelt through the steering wheel so it wont turn.
Also if you do pull the box it would be a good time to check your PS lines and the rag joint on your steering shaft.
ravingmadman
ravingmadman
Greater Seattle
I agree with the post above. Respectfully, I don't agree with the air hammer comments though. That scares me a little. You don't need an air hammer. :)
Keep wrenching!!!!!
:headbang:
MotRhead
Alberta canada
Im telling you , doing this yourself is not very rewarding. it took me 4 hours to get 2 nuts off my truck.
using the haynes manual also licks poo hole cause they do not tell you the steering box trick
now that i have read this i can go finish up
k gee
Los Angeles, CA
So how'd it go?
Also what's the MOOG PN? I show this on RockAuto.com
MOOG Part # K6335
Frt Strg $42
Also
Idler Arm
MOOG Part # K6447
Frt Strg; Problem Solver; w/o frame bracket $63
Do we need an idler arm with frame bracket or not? Prices seem ok.
OP, how did it cost you $20? You get the part cheap?
MotRhead
Alberta canada
im still not done , got called into work and then started raining ( no garage ) , plus some other excusess
i have the steering box off but trying to get any torque on the puller is killer cause i don't want to damage the steering hoses , hopefully i will have 2 full batterys in my impact gun so i can blast that ***** off
k gee
Los Angeles, CA
Yeah...I've been feeling pretty lazy. Thinking about just paying to get the work done.
BrakeMasters wanted about $500 to replace the parts though...and I would not go there, so if it will be about $500...I gotta do it myself. Parts are like $100.
MotRhead
Alberta canada
i finally finished mine today, my motomaster impact gun didn't have the juice to pull the pitman arm off the steering gear , i had to beg borrow and steal a buddy of mines Snap on battery opperated impact , and holy hell thing damn near broke my wrist it worked so well
to bad i didn't have this the first day!!
also you don't need the pickle forks if you have an impact like this and a big enough socket for the pitman arm nut , with the steering box un bolted you can manouver it enough to get a socket on the nut , better option then trying to kill yourself with a crecent wrench and the 3/8th" space you ahve to pull the nut off
next wrenching....rear axle seals and brakes yipppy
99Yuk
Northern Ontario, Canada
I just did my front end today. 4 Balljoints, 4 Tierod ends, Pitman Arm and Idler Arm. My entire front end is now Moog.
http://www.tahoeyukonforum.com/forum/showthread.php?t=12523
It took me three hours just to do this pitman arm job. RavingMadMan's writeup was perfect. I followed it to a tee. It worked like a charm. I took pictures in case anyone else wants to try this.
So here is the original writeup with pics.
Steps:
    I got really pissed at this stupic peice of plastic, so I ended up removing it.
    Apprentice, apeasing the steering linkage gods!
    Me drinking Moosehead.
Don't forget to do the wheel alignment. After changing the entire suspension, I had to do two wheel aligments to get it right. One immediately before it left the hoist, and another after a good 1/2 hour run on the highway/gravel roads. It was out again (just a little) after things settled in.
I am so sore, my arms are all scratched up.
Big THANKS TO RavingMadMan!
Too bad you don't have a writeup about changing the idler arm. I didn't know that when you tighten the main nut, the shaft would turn with it. That was a b&tch to get back on! Certainly could have used a trick there! I ended up using an 8 foot pry bar to put upward pressure on the idler arm, while the apprentise wrenched the nut. The upward pressure held the shaft in place.
Next up, try to find those rotors and pads that you guys are talking about (Hawks?), install my new SS brake lines and flush/replace the brake fluid with ATE Super Blue. http://www.tahoeyukonforum.com/forum/showthread.php?t=15370
armandjones82
Banned
I'm just new in this forum, and I must say the DIY instructions on how to replace a pitman arm in my car was showed very well. With the visuals and step by step set, I was able to really appreciate your post. Keep it up!
faze
British Columbia
I used the original post to do this job and can add two things...the irritating clip comes off with one bolt...worth removing.
To undo the pitman arm nut I took one of my tires off, used it as a backrest and pushed on the cresent wrench, kind of like a narrow grip bench press, and was able to generate enough force pretty easily.
lknox21
Instead of killing my back and knuckles while not using an air wrench, cant we use a cheater pipe at the end of the uber crescent wrench?
I like to work smarter not harder if possible....
P.S. Nice lift 99YUK :rocking:
laxman21
Wow! those are some high prices. Had the pitman and idler with bracket change for lee than $200 for the labor. I bought the parts.
Jim_Rockford
Just did mine, only 1 more step and its easier just to pul the whole box out of the front and put the box on a bench and I cut a slop in the old pitman are and a couple of easy smacks and it fell right off, plus you get to flush the power steering system.
CrackerJack135
