Escalade side mirrors on a Tahoe LTZ!
TooMuchTxn
Houston, TX
Hey everyone! I really hate the smaller rectangle mirrors on my 2016 LTZ and want to upgrade them to the larger more square mirrors on the escalade (PN# 23331704 & 23331705).
Has anyone done this swap? Any major issues?
I was able to pull a pair from a buddies salvage operation for cheap cheap but couldn't get my hands on the wiring harnesses.
I know the major difference is they come with video cameras for the surround view. Im trying to get the part number for the escalade wiring harness so i can plug in the cameras also so if anyone has that part number that would be helpful!
Will they still plug up to the Tahoe harness (except the round camera plug)?
Edit: Well i did a search with the correct info and found loads of threads but very little updated information. Will leave this post up in case anyone has any updated info and part numbers!
Thanks!
cmatt
I'm looking into it. There's someone else on here that is working on it too. I'm studying the GM upfitter electrical manual. It shows all the connectors and pin outs...just have to find it in the 1000+ pages.
My thoughts (read, hope) is all the functions are plug and play outside of the camera.
Garen
Van nuys
I personally don't like the escalade mirrors. Chevy and gmc look much better. The escalades mirrors look like dumbos ears.
PG01
Up here to the right
The problem with the stock mirrors is they are way too small. My neighbors kid has one of those battery powered cars to ride around in and it has bigger mirrors than my Tahoe.
Crazy, i just passed 2 new hoes on the way home and said to myself why the hell did they make the mirrors so small, but i was never in a newer one so maybe they are fine... reminds me of the fox body mustangs......
PG01
Its the same f'in mirror!!!!!!
The first 2 are mustang mirrors, last is a 16 hoe mirror.....
BK76
Interested as well. When I bought my 17, I mentioned that to the dealer. He looked puzzled and then compared the 17 Hoe mirrors to my 07 Denali.... "oh, yeah, they are a little smaller". I noticed right away and he hadn't noticed in the past 3 years?
I do like the idea of camera on the mirrors as well for turning lanes. Saw this on a friends Honda Accord and thought "GENIUS".
T
TooMuchTxn
Houston, TX
Just an update... Ive bought the mirrors with cameras and think i found the correct wiring harnesses:
23378542 DRIVER SIDE FRONT SIDE DOOR WIRING HARNESS (LABELED 23378542, 23306842, 23296782, 23289588 OR 23276533) (WITH TAPED BACK 7-WAY CONNECTOR THAT HAS 2-3-2 TERMINAL PATTERN)
23378543 PASSENGER SIDE FRONT SIDE DOOR WIRING HARNESS (WITH TAPED BACK 7-WAY CONNECTOR THAT HAS 2-3-2 TERMINAL PATTERN) (LABELED 23378543, 23306843, 23289589, 23276534, OR 23276534)
Im hoping these are correct since since they are 90$ a pop but they call out the 2-3-2 plug which is the same as the green camera plug that is on the mirrors.
When i get the harnesses in I will update what i find. Fingers crossed...
T
TooMuchTxn
Houston, TX
Got the harnesses in and early indications look good (ie all the mirror plugs have somewhere to plug into the harness). The next step is to see if i can unplug the old harness from the door jam and plug in the new one to ensure the mirrors function as expected before pulling off the door panels.
I hope to do that friday. I will take pics!
cmatt
Is there an additional plug for the door tweeter that the eskys have?
T
TooMuchTxn
Houston, TX
Ok... Mirror update. Basically the Escys are plug and play (at least for vehicles with comparable mirror package as my stock)!
On my 2016 Chevy Tahoe LTZ that came with power fold, blind spot and turn signal mirrors I was able to plug in the two Escalade mirrors and have everything work with the OE harness. This is a 10 min project to just swap the mirrors and retain the stock functions from the original mirrors. Search youtube for "How to Remove and Reinstall Front Passenger Door Panel 2015 Chevy Tahoe LT" by 1A Auto and they have a great tutorial.
I'm traveling this coming week so i didn't have time to swap the whole harness to the updated one with the video connector. I tried just unplugging the door harness and plugging in the new one outside the door but not everything functioned and no video. So i don't know if it has to complete all the circuits or something before everything works or if the video needs programming. Going to research more about the 360 view and come back to the full harness. I couldn't see inside the door completely to compare harnesses to see if there is an extra Escalade speaker connector on the new harness but looking at the parts diagram i think the extra Escalade speakers might be included in the main harness that the door panel connects with.
The Escalade mirrors i used with my stock harness:
gm 23328936 left mirror
gm 23328927 right mirror
The ONLY negative from my personal install experience is that it appears that the Cadillac pearl is slightly different than the Chevrolet. Nothing that the normal person will notice and when i get my grill sprayed i will get them repainted.
I took pics of the blind spot, blinker and puddle light working.
Blind Spot:
Puddle (and also power folded):
Turn Signal:
I got the mirrors on eBay. I lucked out and got 1 for 99$ in the correct color and the second for 185 and had to buy a 30$ color matched cap.
I also went ahead and picked up replacement door panel clips off ebay (cheapest place i found) OEM GM: 11547601. I would HIGHLY advise getting at least 4 of these since some of the retaining heads break in half.
beachcomber
You know, I wasn't sure how that would look, but wow. That looks stock and size appropriate. Great mod. I have an LT, so no power fold, blind spot, etc. I'll need to research how to fab this to mine. Thanks for doing this. I see a project coming for me now. :)
Edit: did you also have to purchase a new switch?
Blind Spot:
Turn Signal:
I thought you got the mirrors from your buddy's wrecking yard? Either way, sweet mod! Now if these would work with the nbs!!
6point2lovelifers
