mals
Today I started with a bottom button because that's where the lights were out. After I messed the harness all up, I decided to pull the airbag to see if it would give me more slack. It didn't make a difference. I adjusted my method a bit for the other side and it was no problem. Still pretty tricky, but done quite quickly with no damage.
I removed mine without needing to pull the airbag, but when it came time to reinstall, the lower two were just too short to get them in the sockets. I tried the needle nose trick, but they were still way down in the well. I popped the airbag, and while it was off I pulled all four harnesses back into the center of the steering wheel and re-routed them all in a more direct path that gave me plenty of slack at each location. I figured that way the next time I (or someone else) needs to do it the process will be much easier.
