What amp wire is this ?
Fleetgeo
I have a 2001 Yukon Denali with Bose amp I noticed there was a wire disconnected anyone knows what wire this is to and what it controls
How's the system work? All speakers and tweeters working? Did you look inside the plug itself or the loom for a broken wire?
Fleetgeo
Fleetgeo
I thought it was a stripped wire but that one in the front to the radio is the same way and the only speaker not working is my front passenger side and my subwoofer but idk what wire that's to
Looks like some sort of ground wire
Or like speaker wire with the insulation stripped off.....
I have that same amp and it's mounted in the cubby of the rear panel so I can pull the screws tomorrow and see the plugs better. I just looked and I do see something that looks like the same kind of bare wire but I need to get a better look. My guess is also a ground wire.
Fleetgeo
Fleetgeo
Thanks @redrocket I appreciate that help very much
I can't get my amp back out so I can't unplug the connector but it looks like there's a bare wire like that that goes to the connector. It must be an amp ground wire but I can't tell which spot it goes to. If you look at the connector closely you should be able to see a pin in there that doesn't have a wire attached to it. If a cavity in a connector isn't used it will be hollow with no pin in it.
Fleetgeo
Fleetgeo
Yea I read up on it and it's a drain wire I just have to get a diagram to see where it goes to what happens if this drain wire isn't connected ?
Fleetgeo
Fleetgeo
What's a drain wire? I've never heard of that before.
Still confused myself I was looking up online and I ran into a post that described my situation it was said that a drain wire is similar to a ground for low resistance I'm still in need of help lol
Fleetgeo
Fleetgeo
Usually, rather than attempting to ground the entire shield, the drain wire is used to terminate and ground the shield. A braid is a woven mesh of bare or tinned copper wires. The braid provides a low-resistance path to ground
This is the exact words stated on the post I looked at not sure if it's accurate because I my self never herd of a drain wire
Cattivo
The Concrete Jungle
I'm an electrician, a drain is similar to a ground wire...that wire is considered a secondary ground which will help in reducing static, engine whine etc. to your stereo system...best way to describe it is, if you have ever stripped back the insulation on a coax(home tv cable wire) there is the middle copper conductor then white colored dialectric then the silver braided ground(drain) then insulation. The primary ground on coax is the connector itself
It is your secondary ground which should be grounded on its own, not with the primary ground
So it shouldn't just be hanging like that? I've never seen that before, purposely left that way.
The connector is crimped to the braid on coax , so on a coax there is only one ground which is the braid, designed to keep out interferance. From what I could see on mine, the braid on this isn't on a coax but on a regular wire harness. But anyway, according to what I've read on the GM system with the Bose Lux system (which is different than the standard Bose system) , the audio adjustments (bass, treble, balance, etc.) are carried through the system bus back to the Lux amp in the rear which is supposedly a "smart" amp with a microprocessor inside it. And that braid is indeed supposed to keep external interference from being introduced into this system bus line. I'm not sure if they wrapped it around the bus line or around the speaker/ power wires coming out of the amp but I do agree it should be grounded. Probably won't keep anything from working but it might increase the chance of noise if it isn't.
Cattivo
The Concrete Jungle
The coax- braid(drain) was crimped to the connector on older styled RG59 coax wire utilizing the braid as a primary means of grounding...on newer styled coax RG6 the braid(drain) is folded over the cannon head connector 180 degrees and used as a secondary means of ground to eliminate static and bleed over. The outer perimeter of the RG6 connector is self grounded when tightened onto a splitter
I don't have the Bose Lux system in my truck so I can't elaborate if that drain was mistakenly disconnected or bypassed for whatever reasons. It certainly wouldn't hurt to ground it as you mentioned.
And I just gave away how long ago it was that I was an electronic tech! It's been quite awhile. The concept is still the same though, and of course we're talking an old GM system although it works well.
Merch619
