Need help on installing a DD unit in my 04 tahoe
vatahoelt
NoVa
Okay, so I've been looking into buying new DD DVD unit. If I've read correctly, in order to keep my xm radio, steering wheel controls, and to use my factory bose system, i'll need the following adapaters?
PAC OS-2Bose
Kenwood KCA-XM100V XM Adaptor
Audivox CNP-2000 MiniTuner
SWI-JACKxxx
Does anyone have any opinions on the particular adapters out there?
Any help is appreciated.
Anthony
2004 Tahoe LT (MA)
Westen MA
I used the GMOS-04 in my 04' Tahoe LT with Bose and Onstar and overhead video and it works great :)
NJ04HOE
Paterson, NJ
That's what I used too, for the steering wheel controls I used the PAC-SWIX (I think that was the model) but there may be a better one out by now.
V
vatahoelt
NoVa
cool, thanks for the replies. it was pretty straight forward installing it right? wire color to wire color.
also, do i need an antenna adapter as well for the regular am/fm radio?
kirkpatrickdg
Portland
yeah you need a motorola antena adapter.. Look on crutchfield it will give you the right adapter listing...
V
vatahoelt
NoVa
seems to be a pretty big pain in the ass to convert over to a DD. are there any XM tuners out there that will use the stock antenna and wiring?
Anthony
2004 Tahoe LT (MA)
Westen MA
Its not a pain at all in 2003-2006 Tahoes, It is very difficult for 2000-2002 Tahoes, so you should be all set
V
vatahoelt
NoVa
i'm just thinking that I need an antenna adapter, a bose adapter, a steering wheel adapter if i want it, a new xm tuner, which i'll probably have to run a new antenna for it somewhere.
maybe i'll just get a tune and some longtubes.
Narco
Atlanta
i know, when i saw what all i needed to keep the stuff i have i decided to stay stock
V
vatahoelt
NoVa
i'll probably go performance instead. tune, LTs, and maybe efans. i'm sure all that will be more fun than a dvd player in my dash. ;)
V
vatahoelt
NoVa
PAC OS-2Bose
SWI-JACKxxx
so i got the kenwood ddx514, xm tuner, pac os-2bose, just waiting on the xm adapter before I install it.
one question on hooking up the parking wire. just hook that up to the ground to get it to play while driving? is that correct?
V
vatahoelt
NoVa
so i could just hook it up to the factory ground wire then?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
on the xm antenna- every vehicle i have ever seen, every antenna I have ever seen, all have the same connector. The plastic shell may vary occasionally, but the actual metal connectors are the same once that is removed.
V
vatahoelt
NoVa
you're saying to hook it up to the ground wire from the xm antenna?
Eagle
EL PASO, TX
I see where the confusion lies...
Guess I should have types RE: xm antenna... (as in not on the most recent subject)
Ie you don't need a new separate antenna if you already had xm and are going aftermarket xm.
V
vatahoelt
NoVa
oh okay, i see what you are saying now. i hope you're right that i can just hook up the wires to my new kenwood xm tuner, but i have a feeling i might need to get this adapter to make it work.
http://www.myradiostore.com/p/gm-dual.html?_sNavAssistFrom=crsl-p2a1
i haven't pulled down the glove box to see yet though. if it's just 1 plug from my antenna, then i should be good.
V
vatahoelt
NoVa
one last question. where can i tap into, to hook up the reverse wire?
TejasPitt
