2001 tahoe swapping led to ac controls
mbp1979
North Little Rock
Has anyone swapped the bulbs to led in the ac controls. I've found the regular controls like in the truck in the search but not the one in my tahoe with the auto control features there different. I've swapped everything else but these they have me ready to pull my hair out.
I gave up on doing the auto AC controls in my Denali after ruining the main one . The circuits made no sense to me, a combo of series and parallel. I could get most of the lights to work and then after adding another some would go out. Frustratiing.
M
mbp1979
North Little Rock
Well that's not what I wanted to hear. I'm going to firgure it out if it kills me. I got both the front and rear upper controls done just need the main one now. I afraid my board is bad cause none of the lights worked on it before I started.
It's a weird one; part of it is like the Christmas light strings where if one bulb goes out the whole line goes down. Problem is, you can't keep removing and resoldering bulbs in or the pads get trashed. Good luck.
Archer04
I did manage to get my a.c. controls to swap to LED, I will post a pic let me know if yours looks like mine. Maybe I can help.
It is not the best pic but you can see they are lit up in blue.
M
mbp1979
North Little Rock
I got it all lined out just had to put resistors on each led and finally just trace each circuit with a meter. Mine was the 99-02 with the auto control feature all the ones you see are the newer model like you have or the older like mine but without the auto feature just 1 through 5 thank you for trying to help a brother out.
Archer04
I had to use resistors for each light, test polarity. Also be very careful with the soldering iron, it is easy to melt or cause a break in the card from the heat. I also used a 9v battery for testing, the way I did it was to connect a light with resistor to the board and then verify it lit up as well as any that were already connected. Kept that up til I got the last one done. Another thing to do is instead of desoldering the old light from the backside of the card is to cut the old bulb off from the front side and then solder to the old post, this will prevent from having to touch the card to remove the old solder. Finally I never said it was perfect, I did burn my card as mentioned and then had to troubleshoot to find where I needed to make a jump between the lights to get them to work, again this is where that 9v and leads come in handy.
M
mbp1979
North Little Rock
If you use fine tip on ur solder iron helps greatly when you remove and resolder the leds in the board if your using just a standard tip it's alot easier to screw up and put to much heat on it. Not that it doesn't or won't but definitely less room for error.
Archer04
Yes and if your new to the use of a soldering iron and don't properly tin the tip and then keep it clean as you work this will also create problems and the potential to burn the board. Also like I said I tested after each LED was soldered on, be careful with that as well if you touch the wrong part of the board you can cause an arc which will short out the board.
Cattivo
The Concrete Jungle
I came up with a different method. If you want to change every bulb to blue led without ANY soldering, check out my build thread... page 12 starting at comment #119...for the upper controls, 4x4, headlight and fog light switches skip to page 15 comment# 143
That looks a bit too much, too bright. Let me guess- led strips?
Cattivo
The Concrete Jungle
They're 5mm blue led's, my phone takes really bad pics and makes them look brighter than they actually are. They would be the same brightness if I chose to solder them in. It's a perfect glow of blue throughout the cabin, not blinding at all
Archer04
I used the 5mm also in my build, but I did use 3mm in a few spots where I thought the bulb needed to be smaller. Also I used flat top blue LED in spots for better diffusion of light. Yours looks great, nice job @Cattivo
HeavyHoe03
