heated seat not working....
redneckgearhead
My wife's 07 seat heat works great when remote started, but when the key is put in the d side seat bottom goes off and won't come back on, no light on the switch.
badzr1
Mine is the same way also a 07 ltz They will work after a remote start and when the key is turned to on they are suppose to shut off. My back will turn back on and lights up but I can not turn the bottom on. No lights.. Still looking for the problem.
redneckgearhead
I'm thinking it's the switch. Have you replaced that yet?
badzr1
No I have not replaced it. I would like to find a wiring diagram or some way to test it.
Susan15
Curious if you found the answer? I have the same problem. Lights up and heats up with remote start, but nothing when turned on. Sure sucks when it's -1 out!
badzr1
Found the problem with mine. The button for the bottom was pushed into the switch too far. Removed door panel to access switch and just popped the button up (it came right out) and reinsert button. Test while the panel is still off. Works great now. Again mine was working with remote start but once started I could only turn the back on and not the seat.
TejasPitt
