Speed engineering long tubes
Doesn't really fit right. Had to remove the front prop shaft, it's right on the transmission or against it, and it doesn't line up with the factory exhaust.
svtthis
Doesn't really fit right. Had to remove the front prop shaft, it's right on the transmission or against it, and it doesn't line up with the factory exhaust. View attachment 74000 View attachment 74001 View attachment 74002
Is that the speed engineering y along with the headers?
I never tried to hook mine up to the factory exhaust that's probably why you are having trouble.
Also I read that of your motor mounts were failing you would have fitment issues
Yes, you can hook it to your factory exhaust. The motor mounts are fine, two different guys checked them out and they're fine. Speed Engineering tried to tell me they we're bad also, they're not. They have terrible customer service.
svtthis
I read the motor mount "issue" on pt forum and one of the reps from speed Inc said that was the problem for his fitment issues as well. Looks like it's a bigger issue than I thought. You're the 3 person talking about fitment issues I've seen. I guess I got lucky. I hope you get it worked out soon. Looks like speed Inc forgot the service part in customer service.
Im an owner/operator and customer service is more important then people think. If you have a mediocre product but great customer service you're more apt to be forgiven, instead of having a really good product but mediocre to non existent customer service. The few times you have issues and don't address it, you'll never be forgiven.
Still no solution @Tonyrodz ? This must be killing you to not be able to drive that thing with your new 6.0 in it!
HELL YEAH, it's killing me. It's been a month already. Supposedly I should be getting it back this week. Everything is done except for the exhaust and the tune. Side note: Found a dual electric fan set, with radiator for $125, but I don't think I can get to it, and the guy doesn't want to meet up. Sux for me.
I bet if you take that to a muffler shop they could mod that y-pipe and get the exhaust hooked up for pretty cheap.
OK I have a question - if you do the off-road y-pipe there's no cats correct? How do you pass emissions?
In NJ I could take it to a private inspector, but I have to find a friend of a friend deal. Or.... I was able to find a cat convertor heat shield that I was thinking of trying to attach to the y, somewhere, so it looks legit. Because in NJ when you take it to state inspection, you have to drive it over a camera, where they look for, what appears to be a cat. Also, as long as your check engine light isn't on, and, visually, your cat is there, you pass. No sniffer test. I just had it inspected and we have 2 year inspections, so I'm good until 2018. Hope to have it figured out by then.
mmeachem
What's the general verdict on these? Better options at that price, probably not. I have a 4wd too but don't want the same issues.
95escahoe
Some people they fit great others run into these issues
It's exactly what @95escahoe said. Sounds good, but if I knew the problems I was to have with them, I would've went with another company. Also, their customer service is pretty much non existent. I explained the issues I was having, and they pretty much said my motor mounts we're bad, they're not, and no one has ever had my problems that I'm experiencing. And, if I no longer wanted the y pipe, just send it back. If only it was that easy. I already had told them it was on the truck.
mmeachem
Sorry to hear that hopefully when my time comes around they'll have it straightened out.
95escahoe
Or just save up and spend money on a better setup better then risking it and maybe having issues, it's not a new issue people have had issues here and there for awhile now
varminpoolteam
