Converting 2005 Tahoe LT to Bluetooth with Streaming?
Jester9456
I just bought a 2005 Tahoe LT, and I must say she's a beaut. I've been doing research on getting it blue tooth capable. Even though its pricey, so far the most attractive option is the Costar Bluestar II. The trouble with the cheaper setups is that none of them use the built in MIC. I don't want 2 mics mounted and the Bluestar accomplishes this.
Here's the rub:
1. Bluestar replaces the OnStar module. I don't use onstar, but I like the idea of being able to tap the emergency button on the rear view mirror if the need ever arose. Yes, I might have my phone, but I also might not. I like redundancy.
2. In order to stream stereo audio with the Bluestar box you still have to run a 3.5mm audio wire out of the Blustar. I've seen the method of installing an aux plug by splicing into the XM audio wires, but I don't want to do this. It just seems like there may be a more elegant method? Though this might be a whole mess easier than trying to install a more legit aux port.
Maybe there is a better recommendation out there?
My desire is to have hands free calling with stock mic and controls, Bluetooth stereo streaming, maintaining OnStar functionality, maintaining XM functionality. Not having to share my aux channel with XM, No installation of a separate mic or removal of stock hardware.
Questions:
Does the stock head unit have the ability to add a aux plug that isn't a splice job? or does it have one built in perhaps?
I have the RSE system that comes with a DVD player in back. How does that factor into things?
Is there an aftermarket head unit that will maintain stock chimes, wheel controls, and offer hands free over the stock mic?
How hard(impossible?) would it be to adapt Bluetooth modules from a newer Tahoe into my 2005?
Any advice is much appreciated. I love this truck! Looking forward to keeping her clean and pretty for years to come.
adventurenali92
Big Bear Lake, ca
Nothing aftermarket will retain the factory chimes and steering wheel controls. If you go aftermarket head unit you will need the modules for those. I had to do them with my clarion head unit in my 2006.
I would go with a quality aftermarket touchscreen double din DVD receiver with the necessary add on modules to retain factory chimes and steering wheel controls and add an XM module to it. You would replace the factory mic. Your OnStar doesn't work anymore I don't believe- have you tried it lately? I think it's outdated as far as the signal it uses. Not sure about the rear DVD but a backup camera is easily added to this. It updates the system to the latest technology. I did this in my '02 and love it. You can have iPhone or Android screen mirroring also.
YukonXL04
The Riverboat
Arlington, TX
That's a pretty long list of demands there bud..
First off... nothing from 07+ will work in ours. Different data system.
Second the factory radio does not have an aux anywhere, I believe pac audio makes a kit to add one in where you could keep your xm... May be wrong though.
As long as you keep the factory radio, the RSE should still work. I have seen that most people who replace their radio end up losing their RSE controls on the console.
No, aftermarket radios won't be able to use the stock mic. Just remove the stock and mount the new one in its place...
Yes you can buy modules that will retain chimes, steering wheel controls, Bose.
Also I believe your on star is outdated as well. I think they do make a kit for yours though to update to a newer compatible setup.
NathanJax
Vacation Nathan
Jax, Fl
If you purchase the right harness, and have the right options, RSE can be retained.
mals
Western Mass
I purchased a new old stock BlueFusion BFCL2K Kit on ebay for $50 when I got my 2005 Yukon. It installed in a few minutes by connecting it to the XM module behind the glove box and running the mic up next to the OnStar mic. I slid the OnStar mic forward so it is out of site and mounted the BlueFusion one where it had been mounted. Everything works as factory, but the first XM preset station is now labeled "BlueFusion" and if I select that I can stream to the vehicle. This was supposed to just be a temporary setup until I figured out what to do next, but it's worked so well, I have no plans to change it.
dak244
I'm not sure this is true, is it? Per Crutchfield, you can get an aftermarket HU (i.e. Pioneer 4200) with the PAC RP5-GM11 set up to retain the use of steering wheel controls and factory chimes.
Or am I missing something on that setup?
What @Bigbeardenali1992 was saying is just that- you need the modules like the PAC one to retain those factory items. The HU's themselves alone won't work but add-ons like the one you mentioned will allow it. I'm not sure on the exact PAC module needed for that vehicle. I needed 2 separate ones for my 2002 Denali.
adventurenali92
Big Bear Lake, ca
@Red Rocket is correct. The unit itself doesn't allow. And my 2006's stereo setup is like his. I needed a chimes module and a steering wheel control module so 2 separate setups as well. Not sure on the brands of those as it's been a while. There are many threads on here in that topic that I've seen. @dak244 , crutchfield sells the Pioneer with the Pac already bundled with it.
dak244
Gotcha, makes sense. Thanks for clarifying!
W8TVI
Traverse City, MI
When I installed the the aftermarket HU in my 2000 Yukon XL, I simply removed the onstar mic from its location and clipped the new HU's mic in its place.
I didn't even unhook the onstar mic, I just placed in inside the overhead console.
Seeing that it was a 2000, I didn't need any modules for it (no steering wheel buttons), but from what I've seen they are easy to install.
bigblue05
where is the on star mic i have the blue fusion as well and it came with its own mic
Herb Rodriguez
I found a product that satisfies most of the criteria mentioned about except it requires and separate, additional microphone. It's called iSimple Connect. Model ISGM655. I retained all factory capabilities with the Bose and RES except for XM and I think they have an optional module that even keeps that functionality. This $100 kit on Amazon gave me bluetooth so I can listen to Pandora, handsfree calling, USB and a 3.5 plug. I just installed it today. Took me half the day as the guy who worked on the dash prior to me buying this 03' Yukon XL trapped the wires behind the Bose headunit and it took me forever to be able to get my hands behind it to disconnect the wires. After that it was pretty straight forward installation. Sounds great!
Why didn't you just remove the head unit? It's only held in with 4 screws.
johnsonwillie199
