warm up time- noisy lifters
cmc76
ok, so after debating on it, im getting a remote start put in today.
Naturally if you look up information on the topic, google will tell you to only warm up for 30 seconds.
well, with 175,000 miles i have some ticking at start up in the cold, and its been my experience that in a vehicle with some miles, if its going to break it breaks in the cold.
So im interested in other peoples opinion, especially since we all have essentially the same driveline.
It doesnt seem out of line to let my truck run for 5 minutes before heading out when its 20 degrees outside.
thoughts?
RaiderRodney
Burnsville, NC
I have an 01 5.3 with around 144,000 on it and since changing to Penz Ultra Platinum synthetic I too have a little bit of lifter tick at startup. I usually let it run for a couple of minutes to let it stop before pulling out. There are a lot of people that say the engines are designed to be started up and drive off right away...but I guess it gives me a little piece of mind, even more so when it is really cold.
Bowzer
SoCal
I alyways let mine warm up for about two minutes. 01 5.3 with 136k and I have used Mobil 1 10-30 since the second oil change. It's had the lifter tick since new. Runs like new and only burns 1/2 quart between changes. Valve covers never been off. A cold start here would be 40° though.
dantheman
Houston
if you are getting ticking it might be time to pop the heads off and put in new lifters. after having a camshaft and motor destroyed by a failed lifter that i said "itll be fine for a little while longer" i listen when they start ticking. we did a head swap to ported 241's on my wifes 04 gto and i thought it had an exhaust leak since we were originally doing shorty headers that ended up in a head swap im glad we did because it had 8 collapsed lifters just waiting to nuke the motor. its not a super difficult swap either just time consuming.
YukonandtheHOE
Probably an Exhaust leak? Can you see all the bolt heads on the manifolds?
rndsommer
I have an 01 tahoe with a slight knock on cold start ups regardless of outside temp. I've had a few other 5.3s in different years and they all did it regardless of type of oil but always ran mobil1 synthetic. Maybe piston slap? They all ran great with zero issues. Goes away after 30-60 seconds. I use the remote start so I don't have to listen to it from inside the house.
Bowzer
SoCal
My 5.3 has done this since new and the dealer referred to it as a lifter tick. I've been in several 5.3s that do this too. Guess it justifies the remote start!
Bowzer
SoCal
That's a bummer but at least a good excuse to do some upgrades. How many miles when the lifter failed?
Yukon2000xl
All my lifter ticking went away after oil pump change.On cold my oil pressure is 70, before when I bought the truck it was 40psi.Now warm it drops to 40psi
dantheman
Houston
the GTO had 104k miles when we pulled the heads but it had been ticking for about 5k miles or so.
cmc76
cmc76
For me, the tick only seems to occur at less than 30 degrees outside. if i start and go, its more pronounced under load. if i let it warm, goes away in less than 2 minutes.
I have not pulled the valve covers to inspect, but based on everything i have read, its not uncommon. With the miles i have ( 174k)
I am not going to worry about it much, other than making sure i am warmed up.
I went ahead and had the remote start put in last week, thank god. It got really cold, really fast and its been a great addition.
The reason i initially asked about warm up time, is prior to the tahoe i had been driving a cummins diesel for about 10 years.
With the diesel , when cold you can have fuel get by the rings at idle. Which is why they use a high idler for longer idle time.
shoredune
thoughts?
Put some rislone in there and a can of restore works wonders!
retiredsparky
Many GM engines have piston slap when cold. The pistons have short skirts which allows the piston to rock as it goes up and down. After the combustion heat expands the piston, the slap goes away. Most mechanics can tell the difference between slap and lifter noise.
dizhai
