#1taho
5150TAHO
niagara falls ont
If I could just use the trans temp gauge in my old cluster, I'd be happy. @#1taho, do you have a pic of your cluster with the truck running?
No but I can get one. You should be able to change out your gray circle for the chrome caddy one and keep the stock look. Then it will look like you want with the temp gage.
bottomline2000
Dallas, TX
Can you swap the face in the cluster. I know the Denali one I have is too bright and I'm just going to swap the face with my old one. Don't know why I didn't do it when i put it in. Glass is in it but hard to see..all one piece..
Sent from my SAMSUNG-SM-G900A using Tapatalk
The clear plastic and the outer gauge face covers are one piece. I don't think the Tahoe one will match up.
Knope
NC
Put on non-z71 rear springs. Now I need to find someone to buy Tony's Belltech front and rear kit from me. It'll make a great X-mas present!
BADRIDES
Why the spring swap? What that do for ride height?
95escahoe
Had the shop do the valve cover & intake gaskets, along with the knock sensors and harness it was pretty nasty under there hopefully my idle issue is fixed now
Fosscore
Hope that fuel pump issue is sorted. Especially now with that good looking exhaust parts you have waiting to go on soon.
Headers and y pipe should be here this Friday. Already got the cats.
I went with the mid range pump the first time, and I was the second customer that had a failure this week with the same pump, so they hooked me up with the top of the line this time-FREE! :chewie:Yeah boiiieeee!!
ASG-MikeS
