Suspension Suggestions Please
ratedr120
NYC
What's going on group? So My '03 Yukon Denali (NOT The XL) Feels As If It's Time To Change My Suspension. I Purchased Shadow (Her Name) Just Over 3 Years Ago In NYC. Now If Anyone Knows NYC Then You Know How Much Damage NYC Roads Can/Will Do To Your Suspension. So With This Being My First Time Doing The Suspension On A Truck (I Used To Drive Maximas). What Would Some Of You Recommend For Me To Go With As A Set Up? What Brand Of Strut Do You Think Would Be Best? Im Looking For A Stiffer Type Ride But Nothing Too Harsh Either, Just A Bit Stiffer Than Stock. Also The Thing With The Air Ride In The Back? What Can I Do To Just Change It To A Regular Style Setup Minus The Air Ride? My Price Range Is A Bit Negotiable But Im Not Looking To Break The Bank Either. SUGGESTIONS?
01ssreda4
Id take off the auto air level in the back and delete the autoride shocks and install Bilstien 4600 shocks.
ratedr120
ratedr120
NYC
Is That All I Would Need To Do Or Are There Extra Parts That I Would Need For The Swap? I Need ALL The Info I Can Get LoL
dhulsey779
Phila
I actually just installed the Bilsteins 4600 series rear shocks on my lowered 03 Tahoe. Rides like brand new again.
TheAutumnWind
I'd recommend the 4600's as well. Make sure that the jounce stops in the front are in good shape. Actually just replace them, they likely are worn out.
Also in the rear you will want to replace the springs, as the springs are likely worn for one, and additionally are much softer in the airride equipped vehicles since the air shock helps support the vehicle. 81071 is the standard height/duty spring. 81069 is the HD/z71 spring that will leave you with a higher rear ride height 1-2"
Here are the two options:
MOOG Part # 81071 Constant Rate Spring
Bar Size (In): 0.640 Inch
Free Height (In): 16.042 Inch
Install Height (In): 5.266 Inch
MOOG Part # 81069 Constant Rate Spring
Free Height (In): 17.177 Inch
ratedr120
ratedr120
NYC
Much Appreciated, Really! I'm So New To This And I'm The Type That Likes To Leave Zero Room For Error. Just Want To Make Sure I Stock Pile The Correct Parts So I Can Do Everything In One Shot. Also Any Suggestions For Upper Control Arms? I'm Looking To Replace My UCA (Did The Lowers Already)
ratedr120
ratedr120
NYC
Sweet! I Was Thinking Of A Drop, Maybe 2 Inches The Most But I Changed My Mind
TheAutumnWind
I prefer MOOG "problem solver" for a factory style UCA
If you are going that route do the pitman and idler arms, inner and outer tie rods too.
Can the 4600's be used on a non lowered rig that's eventually going to be lowered, with no issues? I also need shocks, bad!
dhulsey779
Phila
Yes it's the same shock application lowered or not. When you lower the rig you use a relocation bracket.
QUOTE="dhulsey779, post: 1049839, member: 33701"]Yes it's the same shock application lowered or not. When you lower the rig you use a relocation bracket.
Sent from my iPhone using Tapatalk[/QUOTE]
Thx guys.:happy160:
ratedr120
ratedr120
NYC
I Was Told That MOOG Parts Aren't What They Used To Be And That Someone Else Purchased The Company. Idk How True That Is, Any Proof?
Knope
NC
Since you know how rough the NYC roads are, I'd recommend staying as close to stock as possible. Lowering it would likely be harsh. I rode on the 2" front spindle drop and the 3-4 belltech rear drop spring for almost a year, and I finally went back to stock MOOG parts. Lowered looks great on 22s or 24s, but is too rough for my personal preference (I only have 20s).
05Single
afraid of the dark
Good to know about the extenders.
Do you own a Samsung phone red?
05Single
afraid of the dark
Lol sorry my samsung galaxy always randomly capitalize letters for no reason.
TheAutumnWind
Did you do the free travel mod in the rear?
dizhai
