Hello from Yukon Canada
YukonandtheHOE
Im a Professional Mechanic and a serious General Motors enthusiast.
Currently have 7 viehicals.
6 of them GM's ofcourse!
the Important ones..
2007 Tahoe LT
1996 Yukon SLE
Well im here learn and share knowledge
Cheers All!
YukonandtheHOE
YukonandtheHOE
2007 Tahoe LT
1996 Yukon SLE
Moe007311
You think its oil pressure sensor or all temperature sensors on both sides block and two wire one by water pump !? I can't figure it out I changed coil and ignition module spark plugs wires alternator it idles then drops after few moments its driving Me crazy lol the last two weeks what you think... lol
YukonandtheHOE
YukonandtheHOE
Im not a psychic:hmm:, what year is your burban and what are your symptoms?
Moe007311
93 I had change water pump after I was done I plugged battery back then I seen hose I need adjust I had extension in my hand I touched the alternator with out noticing and the block then I heard it sparks twice then I said I hope I didn't burn out alternator then I started it started then it died out then I tried again it wouldn't start again only clicks with out turing then I changed coil and ignition module then it started with sound as its miss firing then I changed sparkwires then it started normal and idled for FEW moments with out miss firing then idle drops as its choking then it dies and keep doing it every try I make too start it again in same order / I changed my water temperature sensors 8 months ago and oil pressure sensor you think they burned too it was running perfect before I changed water pump what you think
YukonandtheHOE
YukonandtheHOE
Well, Generally speaking arcing off your alt won't hurt anything. Have you checked all your grounds? Have you made sure its not a fuel issue?
Is the base timing wire some how unplugged? Its located passenger side under the dash, its a one wire connector orange wire iirc. Check the fues's and connections under the cover on the passenger side fire wall. TBI's are pretty much just SuckBangBlow and reliable as hell.. check that stuff out and let me know.
Btw Grammar.. Learn it, love it, use it
CKendrick
