Roof rack screws
Tony
Does anyone know what the screws that screw into the inner sides of the roofrack to hold the cross bars in place are called? or where I can buy them? thanks
Tony
Tony
greenhornet
Ontario,Canada
Thanks for the link, but that is for the roof racks,, I am looking for just the "plugs" that go into the holes that are left after I removed the cross roof racks,,
You could try a body supply shop or a shop that specializes in nuts and blots ,fasteners specialty stores.
Tony
Tony
Agreed,, I'll probably find them at the home depot.. thanks
khiroshima
Just an FYI, they are just janky plastic plugs . . . and I's short, so I can't see the holes anyway :) Letting you know, so you don't spend a ton on filling the holes, best of luck-- KH
2020 Tahoe
Probably just easier to go to the dealer. Less aggravating Imo.
I just bought the crosspieces for my 2020 Tahoe and I can’t get the plastic plugs out of the rack holes on top of the vehicle, without tearing the tops off, which leaves a piece of it in the hole, keeping the bolt from going in. What’s the secret? I’ve tried screwdriver and pliers. Hate to half to drill them all out. Thx. H
greenhornet
Ontario,Canada
They are plastic and will pull out with some prying.They have a grooved shank and hold on to the threads. Just takes some prying and pulling with trim removal tools.(plastic).
PG01
Up here to the right
Just put roofracks on mine a few weeks ago... they screwed right out on my denali..
:shrug:
kurtibm
Grand Canyon
Yes, they unscrew. Why not just replace with short s.s./black oxide button head socket cap screws in there? M6-1.0, fine thread. $8 for a pack of 50 on Amazon, likely less at your local hardware for the quantity you would need.
Hummin24
I replaced mine with stainless bolts. Its a standard size. Bring to your local hardware store to match up. I also used a stainless/rubber flat washer to keep water out.
varminpoolteam
