cardude2000
- Joined
- Nov 12, 2015
- Posts
- 2,931
- Reaction score
- 1,041
but they wont work with fogs on right?
Very nice feature. I drove late last night on a part Huntington/Cold Spring Harbor NY.
Lawrence Hill Rd to be exact and is pretty dark, lots of hills and curves.
High beams were working all by them self. When another car was approaching went to low beams. Very cool!
Now! if I only can figured the Forward Collision Alert...
I have the truck for a month now and it has gone off a few times but what exactly does it do... red light comes on.
It supposed to slow down or just warn you are too close?
Is it when I'm approaching somebody too close or too fast?
It goes off when over passing someone.
I don't know if is in my mind but I feel that the brakes apply them self. Not fully but slightly pressure...
Thanks for the info Broham.
If you have ACC then you have the low speed braking which I think is 5 -35 mph or something it's not at higher speeds. At least that is what they are telling me on my 17 Yukon.I don't know how to test it but I do feel a slightly pull on the brake when that happens(not a full stop) Again could be on my mind and watching too many commercial. (I don't have the adaptive cruise control)
Mines is a latest August 2016 production. Don't know if that makes any difference.
I have a 2016 LT Tahoe and I was wondering how to active intellibeam. I read the owners manual and it said to put the signal lever to neutral and the exterior lights to auto.... not sure if I need to do anything else I have my knob to auto and my signal lever in the neutral position I think? How can I check if it's active?
I have driven in a dark area but haven't notice the high beam light with and A on it before....
Figure it out. If anyone is interested just push the signal lever on to high beams twice within five seconds and you will see a green icon with an A over the light icon on your instrument panel.
Is this feature on the 2015 tahoe ltz?You do NOT have to do that every time you get in car, UNLESS you activate the High Beams manually. Also, if you activate the fog lights manually (only way you can), it overrides the Intellibeam until you turn off the fog lights, or turn the truck off...at which point the Intellibeam will reactivate on its own.
Now, the question is, has anyone actually seen this system work? I only figured out how to activate this myself about a week ago (the activation sequence seems lame??? How about a button or option for this in the DIC???), but I still have YET to actually see it turn the High beams on by itself, even in situations where it obviously could have used them? Do you have to be out in total boonies to get this to work??
