Anyway to turn off V8/V4 "AFM"?
wu6fiend
My only criticism of my new 2016 Yukon Denali is the V8/V4 "Active Fuel Management" feature.
I am very aware of it transitioning back and forth, and the vehicle feels heavy and unresponsive when it is in V4 mode. I find myself accelerating harder than I would normally, just to keep it out of four cylinder mode.
I would like to disable the function altogether, while still taking advantage of the 8 speed transmission.
Another concern is somehow causing a warranty problem by disabling the function, so I'm just beginning to gather information on this subject.
I'm curious if anyone has found a way to simply turn off active fuel management? I don't care about the impact on fuel economy, neither of my two previous Yukons had this feature, and I found their fuel economy perfectly acceptable.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
You can have a custom tune made for your truck. A lot of us use blackbear, myself included. It's one of the best things I ever did for her
Weber Dude
The easy way to do it drive in M7 on city and lower speed roads, then in D when you're driving on the freeway/interstate
gat0r
DFW
tuning or drive in manual (M7), as mentioned above
or range device (rangetechnology.com)
DennisT
That didn't work for me. It still went into V4 mode.
Bigpuddie
Thomasville, Pa
Get a Superchips Flashpaq f5 tuner. Good tunes and inexpensive. Will enable you to deactivate afm.
~the Captain
olyelr
Elk Rapids, MI
What about tow haul mode, would that deactivate it? Although you would get the different shift points, too.
jemilioflores89
