jaxman7
Have been lurking for a while. Purchased a 2003 2WD Tahoe last November and slowly getting some mods done. Last week I bought a set of 2014 Silverado Z71 wheels and had a chance over the weekend to get them painted. Other things done to this day:
-Suburban LTZ lower valance painted black
-Grill painted black
-Truck debadged
-Jax
Stefan Elfstrom
Changed front discs and calipers (from a wrecked 2007 Avalanche)
Direct bolt on fit.
Before:
OhFourChevy
Houston Tx
Well, the 3m tape of these door handle buckets isn't even and not thick enough, so they're not staying put.
The grille needs to continue to cure probably for the next 3-4 days. Then I'm going to wetsand, then hit it with another coat of clear, but here's a pic ad promised. Just threw the grille on just now
a4edwin
ny
Did my plugs and wires #8 had me ready to light the Tahoe on fire!!! 30 minutes to do 1 thru 7. 1hr and 20 to do number 8!!
mattbta
Frisco, TX
Truck was running a tad hot. When it cooled, I added a gallon of distilled to it. Couldn't find any obvious leaks and the water pump/hoses/t-stat were replaced in December 2014 (15k miles ago). Fearing Caster Head issue, took it back to the place that put the pump in. Small leak spotted on upper rad hose where it feeds the pump inlet. Crisis averted.
Probably could have seen it myself had I let it get to temp and checked, but fearing the worst, I just went straight to the shop less than two miles away and it held temp fine. Clamped the hose again and will keep an eye on it.
TheAutumnWind
What makes that plug so hard to get changed out.
Sent from my SM-N910T using Tapatalk
its @ the firewall. Exhaust manifold is in the way a bit so you are flying blind.
Honestly it only took me a few minutes more than any of the others. A handful of various extensions and a swivel made it pretty simple.
TheAutumnWind
Nothing if you have the hands of a 6 yr old, and skin tougher than cowhide, because the A/C pan is sharp as F**k!
LOL.
Well I wore gloves, but I have decent sized hands.
JeffK
