2003 yukon denali build
D
Duramax05blk
NH
before deciding to go white underneath i paint matched the center link, front sway bar, trans mount, engine crossmember. horrible pic to much light in the booth
D
Duramax05blk
NH
the rough country tie rod sleeves would not fit the new moog inner and outer tie rods a little lathe persuasion was required
TheAutumnWind
pulled rear end to clean up and removed shafts to replace backing plates
Kind of odd to me but the new z71 springs are shorten then the factory denali springs but z71 springs are much stiffer, escpecially considering the air ride had been bad for a few years.
got new shafts back in, spray bombed new z71 springs and calipers with new pads and rotors and speed bleeders. Also got stainless braided hoses on and new copper line run along axle
Odd, my denali springs were definitely shorter than my moog z71 replacements.
D
Duramax05blk
NH
odd they are moog 81069 which i believe are z71 ordered from summit
D
Duramax05blk
NH
the moog are little bigger in diameter i believe that is part of there "problem solver" upgrade over gm
1992rs
OR
Sub'd. What did you use for a top mount on your coil-over conversion?
D
Duramax05blk
NH
I'm going to try atomics newer top utilizing the factory mount
Sent from my SM-G900V using Tapatalk
1992rs
OR
Sweet. Looking forward to see how it works out. I would love to ditch the t-bars and go coils one day
D
Duramax05blk
NH
Had a productive weekend. Truck finally seems to be in remission from all her cancer.
Started Saturday early with some striper fishing.
Came home and decided to get started on quarter and wheel arch replacement. Filled both the inside and panel it self with left over sound deadner.
D
Duramax05blk
NH
Drl mod with matching morimoto switchback halos to mount on low beam projectors
D
Duramax05blk
NH
Colormatched housings just need to sand and clear lenses and assembly
D
Duramax05blk
NH
/20160701/935eb8979262edd05f38ff1a4787991d.jpg[/IMG]
Quick complete assembly fit test before finalizing everything
55w morimoto elite 6k i. Belive
D
Duramax05blk
NH
Pic last has headlight on
D
Duramax05blk
NH
Excited to pull the truck out of the garage in the am. Excited to see the finished "sled stops" outside. I hope others like it but either way this absolutely My favorite mod so far.
05Single
afraid of the dark
Damn, puttin in serious work. Can't wait for more cool ideas.
Drewphil
