TheAutumnWind
- Joined
- Jan 8, 2015
- Posts
- 3,254
- Reaction score
- 1,993
the aftermarket one is betterDoes the towing package option offer a bigger cooler??? Why not just get a towing package cooler, and GM parts ?
and bigger
It is a bit but enough that I don't mind it. Actually kinda like that it shows a bit and I perfectly centered it so looks kinda bad ass. Most people think it's an intercooler.
That kit is only for the nbs right?
NBS and NNBS.
If you look closely at the OP's pictures, you can see that the factory horizontal brace is not bolted on. I believe GM changed to welds during the 2009 model year. The Tru-Cool install kit should still work, but you'll have to grind, drill, and maybe tap the holes for the new brace to bolt on.
If you don't want to mess with hard lines, not having the factory transmission cooler makes an install easier, in my opinion. Just get the Derale 13035 adapter and use quality hoses and hose clamps.
To add to the temperatures everyone else posted, my temp without a cooler was always 100 degrees higher than the ambient air temp (whether moving or stopped). I've had this vehicle in ambient temps from the low teens to just under 120 degrees, and that always held true. I have driven in mostly low humidity areas.
After adding a Derale 13403 cooler (different model than OP), my temps would be 70-75 degrees over ambient while moving or with the radiator fans on. While stopped with no radiator fans on, the temps would rise to 80-85 degrees above ambient.
Top is before; bottom is after:
Unfortunately, Derale rates my cooler in GVW and rates the OP's cooler in BTUs, so it isn't easy to make a direct comparison. Stacked plate is supposed to be better than plate and fin, but the different dimensions come into play as well.
My nbs stocker was 4"x12" roughly iirc. My cheapo Hayden 679 is roughly 12"x12".clean install, How did that compare to size of the stocker?
Stock is like half the size more or less. Install was easy peezy. Definitely a good buy.clean install, How did that compare to size of the stocker?
I don't have a factory cooler and live in Kansas. We have temp from below 0 in the winter to around 100 in the summer. I was going to get the tru-cool 40 but didn't know if I needed the bypass? The wife drives it and in the winter she will drive maybe 2 miles to take the kids to school.
