Weak blower motor / fan
Blh1960
Peculiar, Missouri
I would start with the blower motor resistor. They are a very common issue with these trucks. I just replaced mine. $25. 5 min fix.
I had the same problem. You need to change the cabin filters. There are 2 of them, and they are together side by side. Mine were totally clogged. You need to take off the cover that is to the left of your glove box. There is a little panel that gives you access. I broke the clip on the back side because I did not see how it came off. You can prevent that if you are aware. I just use duct tape to hold it on after broke it. This made a hugh difference. It could be a resistor but in 15 minutes you can check this.
C
cptmoney
So I swapped out my cabin air filter; I only saw one. Is there a second back in there?
Just the one made a huge difference. Feels like it's really moving some air now!
C
cptmoney
About to take a peek at the rear blower motor to see what I discover there....
C
cptmoney
Quick correction....I double checked, and yep - two cabin air filters up front. I totally missed numero dos. Straight hurricane force winds up front now! Haha
C
cptmoney
Looks like a super dirty connection between the resistor and blower motor. Not even joking.
Pulled the connection apart, cleaned all the contacts, reassembled and voila! I now have rear a/c. Sheesh. Too good to be true.
Blh1960
Peculiar, Missouri
Your in business now! Cabin filters are the most neglected maintenance item I think. People just do not think about that. My rear blower is not running at all either. I have not troubleshot yet.
Dustpan
