Water spots or automatic wax film on windows
Fishtruck
Hey guys! Newbi here. I just bought a 2007 Tahoe LTZ with great miles and the truck is CLEAN. Looks NEW. Anyway, the only issue I have, is water spots on the outside of the windows. I can't tell if it is hard water stains, or wax residue from the auto washes. I have tried "Bio Clean" with some positive results, but thought I would check to see if you guys have had similar issues and if so, what has worked best. Maybe I simply need to throw in some elbow grease, and give the Bio Clean a few rounds.
Thanks in advance.
Degadep
I've had good results with wheel acid. DO NOT TRY ON WINDSHIELD!!! Test in a small area if you decide to try it and rinse thoroughly. I left it on for 30 seconds or less.
Goodinblack
I Like Tacos
Dirty South
Griots garage glass Polish with their glass pads used on a DA buffer.
Do not use acid.
Rosco
Laf, LA
I used the Bio-clean and it was pretty freakin awesome after a window and a sore shoulder i just decided to get a microfiber cutting pad and a griots buffer...
worked well except you have to touch up the edges..
MountainManJoe
