unlocking a navigation radio
Ron C
Los Alamos, NM
Hello,
I am looking into buying an OEM navigation radio for my 2013 SSV, but more than likely it needs to be "unlocked". From what I read one needs to have the donor VIN for that.
Is that all that is needed? and is it something you can do yourself?
thanks,
Ron
DenaliBQ
look at alpine they make a really nice after market unit for your truck
Ron C
Ron C
Los Alamos, NM
I have looked at some others, also pioneer. But sort of decided that I'd like to keep the truck OEM/factory (same style buttons, lights etc etc)
I used to have an alpine radio in an Audi I once owned.
HiHoeSilver
Away!
Chicago
There was a thread recently on an easy DIY permanent unlock. I think you just have to yank a chip out of it. I'll see if I can find it.
Ron C
Ron C
Los Alamos, NM
Now that would be easy. (and makes kinda sense) I talked to a GM dealer yesterday, they want $50 plus tax, which is not too bad.
)I heard one also needs to reconfigure/reprogram something to use a factory back up camera attached to a factory nav-radio
Ron
HiHoeSilver
Away!
Chicago
Ron
I'm no audio expert, and don't know about the camera thing, but here's the thread I was referring to.
http://www.tahoeyukonforum.com/threads/permanently-unlock-gm-radios-for-free-diy.98706/#post-1180947
Edit: I see now that it says 00-06. Don't know about NNBS. I would hit up youtube.
Ron C
Ron C
Los Alamos, NM
I am not a audio/video expert either, but I can connect wires together and cut a hole in a piece of plastic, buy a new part and try to cut that hole again. (although instead of prying that chip off I'd probably solder it off)
Also, the radio is an 04 or 06. mine is a 14. I'd suspect that 'authentication' part to be integrated into some chip set by now. (so it might not be that simple any more).
SDHanz
