- Joined
- Jun 9, 2009
- Posts
- 8,744
- Reaction score
- 605
UPDATED AUG 04 2017
So you guys know it works fine and I've done many over the years.
I use the 06-09 trailblazer rear ss bag and they go right into a tahoe no problem from 00 to new 2017s. The tbss rear upper crossmember and axle brackets are the same as the fullsize suvs
Now over the years I've been doing this few extra things are needed to make it work right
1) free travel mod
2) djm rear hardware kit with bumps tops which I have for 190 shipped on my store page
3) correct rear belltech shocks which I have for 130 shipped
4) rear spoon kit with del sphere upper and lowera and includes Panhard bar with grease and del sphere tool. 675 shipped thru me. Now I've had prob 15 to 20 people bust the output shafts by not doing the arms. The rear end gets sucked forward when you drop it and driveshaft pushes into trans. Just wanted to give you that info.
Now for fittings you will need a 1/4 to 5/32 reducer. The line coming out of a trailblazer ss airbag is 5/32. Then you can hook to a 1/4 line. For those on a budget they can use any pump station to lift the back of the truck up then lower when they want to.
Also you can tow with the trailblazer 06-09 rear airbags. Ive replaced other bag set ups and tbss bags ride better period.
If you need anymore info just ask and yes it will lay the axle on the frame. People are selling these bags all the time on my trailblazer SS site for like 100 bucks.
Tahoe upper crossmember which has notches already
Tbss bag on right you can see the 3 ears that Stick up which will spin and lock it into Tahoe upper cross member
1) free travel mod
