steering wheel swap
96GMCYukonGT
i had a 91 s15 jimmy with a grant lancer steering wheel i still have the steering wheel and adapter.would i be able to use the same adapter for my 96 yukon gt. it has an airbag but ive seen new cars with custom steering wheels that came with airbags. how would i go about removing the air bag steering wheel without setting it off? can i even do this? any help is apperciated
96GMCYukonGT
96GMCYukonGT
thats all it takes? do i just pop the center out? and it wont go off?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
just make sure you get the fuse AND yellow connector that leads up the steering.
There are type of airbag retention mechanisms below but first a warning:
WARNING: When carrying a live inflator module, make sure the bag opening is pointed away from you. In case of accidental deployment, the bag will then deploy with a minimal chance of personal injury. Never carry the inflator module by the wires or connectors on the underside of the module. When placing a alive inflator module on a bench or other surface, always face the bag and trim cover up, away from the surface. This is necessary so that a tree apace la provided to allow the air bag to expand in the unlikely event of accidental deployment. Never rest a steering column assembly on the steering wheel with the inflator module face down and the column vertical. Otherwise, personal injury may result .
Now onto the fun part.
This is if you have a ball lock unit:
Disable the SIR system. See: Air Bag(s) Arming and Disarming\Service and Repair
Negative battery cable.
Turn steering wheel 90 degrees to access rear shroud holes to inflator module.
Release each of four ball lock fasteners by pushing a ball-point pen or similar device into the end of each fastener through the holes in the steering shroud.
Inflator module (tilt rearward from the top to access SIR wiring).
SIR lead wire from clip on inflator module.
SIR lead wire from clip on steering wheel.
Connector position assurance (CPA) and retainer from the inflator module.
Leaf spring and notch pin type:
Turn steering wheel 90°to access rear shroud holes to inflator module.
Insert screw driver and push leaf spring to release pin.
Turn steering wheel 180°to access remaining rear shroud holes.
Connector Position Assurance (CPA) and retainer from the inflator module.
After you get it out do the horn contact and pull the wheel.
AtomicHoe094
Atomichoe094
cleveland, OH
deff pull the battey cables off wayyy before you work on the truck. Air bags can go off up to 30 minutes after the cables are pulled. Watch out!
SunlitComet
OBS Jedi-Do Good
That is why you pull the yellow connector so the diagnostic energy reserve module (DERM) can't fire it. It is the device that stores the voltage charge. And you don't have to wait a while. The inflator module should not be holding an electrical charge at all. On our trucks anyway.
96GMCYukonGT
96GMCYukonGT
thanks for the info guys what are the steering wheels worth i plan to sell it after i take it out
AtomicHoe094
Atomichoe094
cleveland, OH
better off keeping it if you ever need to resell the truck or go back for whatever reason.. try telling UPS theres an airbag in that box.. HAHA goodluck
willb
