Speed engineering long tubes
mmeachem
In NJ I could take it to a private inspector, but I have to find a friend of a friend deal. Or.... I was able to find a cat convertor heat shield that I was thinking of trying to attach to the y, somewhere, so it looks legit. Because in NJ when you take it to state inspection, you have to drive it over a camera, where they look for, what appears to be a cat. Also, as long as your check engine light isn't on, and, visually, your cat is there, you pass. No sniffer test. I just had it inspected and we have 2 year inspections, so I'm good until 2018. Hope to have it figured out by then.
What's the general verdict on these? Better options at that price, probably not. I have a 4wd too but don't want the same issues.
95escahoe
Some people they fit great others run into these issues
It's exactly what @95escahoe said. Sounds good, but if I knew the problems I was to have with them, I would've went with another company. Also, their customer service is pretty much non existent. I explained the issues I was having, and they pretty much said my motor mounts we're bad, they're not, and no one has ever had my problems that I'm experiencing. And, if I no longer wanted the y pipe, just send it back. If only it was that easy. I already had told them it was on the truck.
mmeachem
Sorry to hear that hopefully when my time comes around they'll have it straightened out.
95escahoe
Or just save up and spend money on a better setup better then risking it and maybe having issues, it's not a new issue people have had issues here and there for awhile now
Laurents10
