Ride Quality for a Truck ?
olyelr
Elk Rapids, MI
Yea. If you have no electronics going to your shocks you can simply replace them with pretty much any shock out there.
OK, Sorry I had to step out, The only 'G' code I have is GU4 and that is a 3.08 ratio and I have a G80 that's a positraction rear and one more is GBAP, That's the exterario paint is GBA is Black. So. . . View attachment 234119
James, for the fronts, look at your RPO sheet for 6XX and 7XX codes. These are for your front shocks. Use these when looking up numbers on ACDelco's website and use your VIN to narrow things down.
Then crawl under your truck and see of the original shock and spring part number stickers are still visible.
brielmo
