My 2011 Escalade Build Thread!!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
just wanted to put this up. Here are the short bumpstops I include in my rear 5 plus kits. Pretty much drill and tap for a 3/8x14 bolt and then i put red locktite on the threds and screw it into the frame. prevents the big metal sound when you cut the rear bumpstop brackets off and its really short so you get the most travel you can
06xl
MD
Quick stupid ? Just want to verify is it ok to jack truck up from rear Axle (center right under gear box) to lift up the entire rear?? Also has anybody sprayed any type of rust proof undercoating?? If so what kind??
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes BUT MAKE SURE you put jackstands under frame. If the jack looses a piston your dead since truck will fall on you.
Administrator
I always use jack stands!! I don't trust that jack for nothing!
06xl
MD
Ooo yes jack stands are a must..thanks fellas just gathering info so when I start on my bbk install I'll be on the safe side..
P.S sorry for the thread jack Tony now back to the build..
THE YETI
Director of Operations
South FL
where'd u end up getting your Wilwood kit from Francis? Just went with the front or rear too? You'll love it, I guarantee that!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Just ordered rear adjustable del sphere bars in black for my truck
http://www.tbssowners.com/store/index.php?act=viewProd&productId=168
---------- Post added at 04:15 PM ---------- Previous post was at 04:12 PM ----------
just added the lower arms
Rear Spohn Del Sphere Lower Control Arms Bar
06xl
MD
I ordered it from BBP an I did front only 16 n 6 drilled/slotted with rear Baer 14 drilled/slotted rotors an caliper relocation and stainless steel lines on all 4 calipers.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Those are badass
ill see what happens on this one because I cant do the uppers due to me having the autoride set up on it and dont feel like welding the brackets on the arms.
abruck
